Question about Beko Washing Machines
How do I stop machine mid program to change to another program?
I accidentally started the hand wash program. I wanted a short program but didn't realise that it would just sit there. Want it to actually rotate and wash. Was able to stop machine and open door but when I started again it insisted on finishing this program and would not let me choose a more a appropriate program.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Go to stop or a program that ir a reset mode. Cheak the make and model and look in you manual that came with the machine. Normally there is a stop mode.
Posted on Nov 09, 2014
Testimonial: "Not helpful. I had no problem stopping the machine or even opening the door. But when I tried to start it again it would not let me choose another program and start again. It wouldn't even let me simply empty the machine and do a spin cycle. It gave me no option but to complete the program. In this case it was simply annoying as the clothes were not getting a proper washing so had to be done again. But had I chosen a program that was damaging my only option would be to take the wet clothes out of the machine - let the program finish while complete empty and then reload and do another program. This makes no sense. It could well have been a 2 hour program, wasting water and electricity for nothing. There should be a way to cancel a program that is in progress. Thank you for any advice you can give."
5 Suggested Answers
SOURCE: Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Posted on Sep 20, 2007
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Posted on Jun 27, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi IZ12 mid program door light comes on.
E40 is a door interlock fault, it is either faulty or the wiring between it and the main board is at fault,
Only way to open door is to remove top cover, and try to force the door open from the inside, if you can see the door latch, try pushing it with a screw driver or something to release it, worst case scenario, is you will have to break the lock to release the door.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
  • 2699 Answers
SOURCE: Have a kenmore elite washing
what cycle does it happen in?close the lid and open it a few times,does it make a clicking sound,if it does i would say the switch is good,also you can do this,next time it happens open the lid carefully without banging the machine so you don't disturb anything,get a screw driver and stick it in the hole and see if it runs, if it does i'd say it's the switch,but i've seen this before right before it goes into the spin cycles,the clutch doesn't fall in the tranny. and when the lid is opened and closed the clutch falls.keep an eye on it and see where on the timer this happens,make a mark and see if it does it in the same spot,depending on how hard you close the lid it could be the switch,the timer sticking,i've tapped the timer when something like this happens and it sometimes starts or the clutch in the tranny,when you close the lid did you ever notice if you heard a clunking sound and then it starts to spin..also if you open the top console,unplug the lid switch and stick a jumper wire in the two outside holes of the part you unplug,the lid switch is closest to the right side clip and it's a white connector, you can bypass the switch to check it, all it is is a safety so the machine won't run with the lid open or instead of doing that you can stick a screw driver into the hole and let the machine run like that if you think it's the switch,let me know what you find.
Posted on Apr 19, 2011
Elextrolux EWF168540 W TimeManager 8kg stopping mid program without any error message
The recurrent problem may be due to a defect in the Time Manager.
Feb 01, 2017 | Washing Machines
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
My Dyson washing machine CR01 memory short circuits after a couple of minutes when I start the program. I have plugged it into another outlet other electricity group, but it's the same problem. Could
Do you mean the program stops working, as usually this means the program controller is faulty, a second hand one may be available on ebay or second hand repair shop.
Feb 09, 2015 | Dyson Memory CRO1 Front Load Washer
Maytag bravo top load remove tub
It appears that you (accidentally) opened or stopped the machine Mid-cycle. Now what cycle that is...Is Unk. You need to first, try not to do this again. Because you shorten the life of the machine and possibly void any warranties. Next unplug the machine overnight. Then next day, Plug back in and start it with out clothes on a short cycle. Should fix it!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jul 26, 2014 | Maytag Washing Machines
My washing machine stops when spinning
Does it stop in long and short spinning programs? Try another program. Start wih emptying program, then a short spin. Kolbrun
Sep 18, 2013 | Washing Machines
How do I cancel a program? I accidentally set it to delay start and now I can't figure out how to cancel the program and reset to what I really want.
push stop or clear button until you hear a beep or the display changes,,,,unplug ....plug back in and choose the program you want
Feb 20, 2011 | Black & Decker Bread Machine
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Samsung smart wash b1245s doesn t work
Oct 13, 2007 | Washing Machines
Washing Machines Logo
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
