How can I fix a faulty vale water vale working incorrect
High level water so that flood but valve do not stop.
  • 3 Answers
The pressure activated switch is turned on to control a shutoff valve when the pressure in the clear tube reaches a certain level. If the tube is blocked, it will not get the light pressure on the air trapped by the column of water. Boyle s law P1V1=P2V2,
so replace (or clean out) tube with the same ID tube or the volume inside will not be correct for the rising column of water to activate the pressure switch.
Posted on Nov 09, 2014
4 Suggested Answers
  • 111 Answers
SOURCE: water level will not stop and floods floor
check the level switch by blowing on it if clicks is good if not replace the switch , make sure that the hose that connects to the switch is free of debri
Posted on Jun 18, 2009
jsrock516
  • 5911 Answers
SOURCE: no water level control
Often, what may seem to be major problems, can be something very minor in nature. It sounds like you have two issues with your washer.
First, the overflowing problem:
The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. Before assuming you have a defective pressure switch, read the following link:
http://www.fixya.com/support/r762094-washer_overflows
In many cases the small air hose comes loose from the pressure switch and causes the symptoms you are experiencing. Check the air hose to ensure it is still attached to the pressure switch and check the electrical connections to ensure they are not corroded. If these preliminary measures do not work, replace the pressure switch. If the pressure switch requires replacement, you can search for the best price at these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The second problem is the agitator:
If the upper portion of the agitator (called the "Auger") is not spinning as it should, you may need to simply replace the agitator dogs. The following link explains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link I provided. The agitator dogs can be purchased at appliancepartspros.com for about $5.
If you have any questions, pease post back with your model number (located around the washer tub opening under the lid) so that I may be able to provide you with better assistance. I hope this helps you.
Posted on Sep 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: Simpson Electronic water not stopping
Pressure switch - it measures the weight of the water (in bars) and tells the valve to close.
Check/replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Wide open throttle there is no rpm like ignition problems has a9 cam big bore kit with the big valves high-performance plug coil and cd put 24mm manual carb jetted
Hi, Larry and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
Good luck and have a nice day.
Jan 05, 2016 | Big Motorcycles
Honda gc 190 starts then floods and stops. Wont start again till plug is taken out and dried then repeats same thing
Float level or a sticking needle valve, check float level as if it is adjusted incorrectly it can cause the main jet to allow fuel to flood through, the needle valve can do the same.
Jul 28, 2014 | Honda Engine Gc160 Gc190 Gcv135 Gcv160...
2004 rsv fuel pump stays on, odom zero, use kill switch to stop, disconected alarm.
Hi, Anonymous and the usual suspects are:
For more information about your question please visit the website below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2004+aprilia+rsv+mille+r
Apr 09, 2013 | 2004 Aprilia RSV Mille R
Fisher and paykel mw512 stops during washing and beeps. the lights for the short wash and rinse stay on. i can reset it by turning it off at the wall and putting it through a rinse cycle. its intermittent,...
12. (00001100) Phase 1 to 6 - Flood Protection Error
The Motor Controller module has found the water level to be above the flood level
and tried to pump the excess water out. (Under extremely high flow rate conditions
the machine may overfill during the "top-up" routine in agitate.) After pumping for
30 seconds, it has been unable to lower the water level below the flood level. Either
the water valves have stuck on and are letting water in at a flow rate that is higher
than the pump can handle, or the pump is blocked and can't remove the excess
water.
Primary Source: Water Valves.
Action:
If the water valves are on continuously, check that the water valves turn off
mechanically (remove power from machine).
Secondary Source: .Pump system
Action:
Check pump for blockage and drain hose for correct height and kinking
Tertiary Source: Motor Controller module. (Display Module Phase 1)
Action:
If water valves are being driven on electrically, replace Motor Controller
Mar 04, 2012 | Fisher and Paykel Fisher & Paykel Washer
Water overflow, timer not working aftre few seconds
The most likely cause is that the fill level sensor is faulty or the tube feeding it has blocked. When you say the timer is stopping, do you mean that it stops the washing program, if so that is normal as the anti flood sensor says STOP because there is a chance of flooding as the water is too high.If you fix the water level it should continue the program after you have drained all excess water.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Washing Machines
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
My RS50 won't rev out?
Hi, Fraser_lewin and the usual suspects are:
DOWNLOAD Aprilia Rs 50
Feb 23, 2010 | 2002 Aprilia RS 125
Water level rose quite high in machine and machine keeps bleeping quoting E16. It won't cancel itself. can you please help? My washing machine is WD71. prior to this after a wash and spin, I would take out...
check the electronic inlet valve I dont know the code but the symptm sound like a faulty leaking inlet valve
as a temp remedy you shoud have a inline isolator check valve this is where the water fill pipes connect to turn them off this will stop the machine from flooding untill you are able to seek repair
Jan 16, 2010 | Washing Machines
The belt broke, it was replaced, but afterwards its overflows,
If water is overflowing check the small plastic line going from the bottom of the tank to the water level switch. It could be disconected. To check the water vales, set machine to fill, while the water is running into the tub unplug the power cord from the wall, the water should stop, if not the water valve is faulty.
Oct 11, 2009 | Speed Queen Washing Machines
My Maytag Washer keeps running water and won't stop.
regardless of machine being on or not???sounds like a faulty water inlet valve youll need to replace the valve..
If the water level just overfills and floods over the top of washer but turns off when the unit is shut off, then it sounds like a bad fill switch.
May 10, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
