Question about Garden
Pull Cord has stripped and won't recoil. Can this be repaired?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Stripped? Maybe the recoil Spring just broke. Easy repair, sometimes you can just re-bend the 'Stop' on the old Spring
Posted on Nov 25, 2014
  • 376 Answers
SOURCE: starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
Posted on May 26, 2009
  • 62 Answers
SOURCE: my echo pb2100 gas leaf blowers pull cord is loose
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
Posted on Sep 25, 2009
bbreton
  • 437 Answers
SOURCE: When I pull the cord, the string is hard to pull
Sounds like you have two problems. One the flywheel brake is not being released completely and second the flywheel key has been sheared. It is why the rope is being jerked out of your hand. The mower is out of timing and when the spark plug fires before it is suppose to, it jerks the rope out of your hand.
Posted on Jan 22, 2010
Testimonial: "thanks for the help"
2strokeJim
  • 577 Answers
SOURCE: My Toro Personal Pace 22"
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Posted on Jul 28, 2011
  • 41 Answers
SOURCE: TORO Model 20016 6.5 hp GTS Engine pull cord is
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Posted on Sep 26, 2011
Coleman powermate vangaurd 9hp. how long is the pull start rope?
no set length on any recoil repair
old one will be stretched or broken
melt cord end for ease of fitting and no fraying through holes
and finishing knots
feed one end into recoil internal through outer and inner casing
then knot
set recoil spring into correct position and tension
cord is at least three times around recoil
leave excess cord out for pull handle and later adjustment
then cut .. melt end .. feed thought pull handle
then adjust as you test recoil off the motor
then fit to motor.. pull a few times
and final adjustment of cord length at the pull handle
Oct 13, 2016 | Coleman Electrical Supplies
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Pull cord won't retract
Hi Susan. It sounds like the spring has either snapped or become un attached. It's going to be a two person job to re do it. It may be worth while going to a scrap metal merchant and getting the recoil starter of an old mower.
Jul 26, 2013 | Poulan Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull string won't recoil
its your Recoil spring that is causing it to do what it is doing it may have came off or broke
Jun 07, 2013 | Garden
Engine doesn't turn over pull cord stuck
remove the starter assembly and see if it is the recoil or engine. if by removing the recoil it recoils the cord then it is most likely a seized engine but pull the rope a few times with the assembly in your hand to check it then try turning the flywheel by hand and see what happens
Feb 09, 2013 | Garden
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
We broke the pull cord and after pulling the cord won't recoil to proper position.
remove the cord assembly ,, either the cord is off track and needs to be rewound or it broke and needs replacement
Jul 16, 2011 | Toro Super Recycler Super Bagger Lawn...
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
