Hi, okay what happens to the battery indicator when this happens ?
Some points to note : the brake could be coming back on , check the brake by carefully touching it after use , take care because they can get very hot..if's it hot ,,, then it's not releasing fully or coming back on due to a brake issue, controller issue or simply a bad connection..
1. Battery & the charger.. Batteries may be fully charged however that does not mean they able to contain the load you place on them .
2. Brake...
3. a worn throttle pot... (WigWag, the go forward lever is attached to one )
At Worse a controller fault.
I offer a free controller test service..
Regards
Rob
www.gewizrepairs.co.uk
Got it sorted it was the throttle pot needed replacing, if that helps anybody else with same problem...
