Question about Garmin Nuvi 550 GPS Receiver
Is there away to enhance the memory of my Gamin 550?
The current N.A. map seems to be to big for the memory. Can I obtain a larger mem0ry?
  • 5,670 Answers
Yes! Memory can be increases using a Micro SD Card!
Posted on Nov 09, 2014
Can I enter GPS coordinates into a gamin zumo 550
Turn on Zumo. Select WHERE TO. Depress ARROW DOWN beneath ROUTES icon. There, revealed, are 5 additional icons, one of which is COORDINATES. There are more different choices of ways to enter coordinates than you're likely to learn what they are in a lifetime.
Happy motorcycling. Keep the shiny side up.
Patrick
Nov 05, 2011 | Garmin zumo 550 GPS Receiver
Im jz wondrin' hw am i able 2 enhance d performance of my pc snce im using an asus p5s-mx se board, intel c0re 2 duo pr0cess0r bt only hav a 1gb mem0ry installed. I als0 installed d l8est wind0w 7 ultimate...
I tnk u shd tri 3gb mmry but best enhancement wud b 2 use prpr English 2 ask ur ques den d ans wudnt b sarcastic. U cud overclock bt mk sure yo coolin is sufficient.
Jan 05, 2011 | Computers & Internet
How to restore garmin nuvi 550 memory to original. i accidently loaded a map to the gps memory and not the memory card. I tried a factory reset but some files are still there and the map does not work.
It's not possible to undo a map install. However you should be able to re-download the original map from the Garmin website. Go to www.garmin.com and log into myGarmin. Click on the myMaps t tab. There you will see the maps you have on your satnav. Under the one you want to install to the satnav click on "Details" which should be in blue writing. This will bring you to a page where you should be able to download it again.
When you have downloaded the first map download the second to your computer. When the website shows that it has found your satnav it will show it with a drop down arrow. Click the drop-down arrow and select download to computer.
After it's downloaded click the windows start button and you will find a garmin icon in your list of programs. Click on garmin and you'll see an icon called MAPINSTALL. Click on this.
When you try to install the map using mapinstall it will again try to install it to your satnav. When your satnav is detected it will again show it with a drop-down arrow. Click this and select your memory card. The map will then be installed to your memory card.
Nov 17, 2010 | Garmin Nuvi 550 GPS Receiver
How big of a processer can i put in it?
current specs:
366 MHz AMD-K6-2 processor with 3DNow! technology.
read this;
http://www.amd.com/us/press-releases/Pages/Press_Release_826.aspx
The K6-2 was an x86 microprocessor introduced by AMD on May 28, 1998, and available in speeds ranging from 266 to 550 MHz. An enhancement of the original K6, the K6-2 introduced AMD's 3D-Now! SIMD instruction set, featured a larger 64 KiB Level 1 cache (32 KiB instruction and 32 KiB data), and an upgraded system-bus interface called Super Socket 7, which was backward compatible with older Socket 7 motherboards. It was manufactured using a 0.25 micrometre process, ran at 2.2 volts, and had 9.3 million transistors.
Nov 26, 2009 | Compaq Presario 1275 Notebook
I want to obtain a larger memory card (currently have a 1GB) but everyone we buy I have been unalbe to get them to format/ I have a pentax ist DS
You should be able to use 2GB SD cards. Cards larger than 2GB are actually SDHC cards and will not work with this camera.
Oct 13, 2009 | Pentax *ist DS Digital Camera
How do i update my gamin nuvi 200 maps?
Go to Garmin.com and then support. Register your device, and you might get a free update, just make sure that you select the same map that is currently on your device. If you don't qualify for a free update then you can buy it and do the same.
Mar 12, 2009 | Garmin nuvi 200W GPS Receiver
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Error message
The WGPX-550 doesn't support 2GB card. You can have Canada on a separate card (512MB will be big enough) and Canada includes the bordering US states
Dec 31, 2007 | Whistler WGPX-550 GPS Receiver
Garmin Nuvi 550 GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
