Question about Car Audio & Video
Where is the best place to find ign feed for connecting to after market radio for 2006 zafira
There is no ign feed to standard radio only battery feed
  • David Harrelson
    David Harrelson Nov 10, 2014
    Many radios are hooked up with only a battery feed, however I don't like this as it means you must remember to turn off the radio when turning off car to prevent draining battery. Use a test light at fuse bax to find a fuse which is only hot when ignition is on and hook radio up there. Some radios have two feed wires, one to battery to hold station settings, and one which actually powers the radio which should go to a fuse only hot when ignition is on.
  • 5,438 Answers
Check fuses
Posted on Nov 09, 2014
  • philip brawn Nov 09, 2014
    what is the pin number and wiring colour for ign feed to radio
I have a question, Where can I find the place of color code in Opel Zafira 1.8 model 2006
engine bay there is a metal plate it will have numbers on it and paint code. near to were the locking pin is on the locator for the bonnet..
Mar 21, 2013 | 2006 Opel Zafira 1.8
I lost the battery connection while connecting new radio and cant find battery wire
I would like to help you, but I am at a small disadvantage here....
You lost WHAT battery connection? WHAT battery wire are you looking for? Do you mean the Keep Alive Memory (KAM) and the ignition (IGN) battery feed at the radio harness connector? Do you think you may have "lost" the battery feed due to blowing a fuse during trying to wire the new radio?
Jun 01, 2012 | Mitsubishi L200 Cars & Trucks
On my 2006 F-150 everytime I go to restart the engine radio resets and tach acts like it is stuck. Any idea's?
Check the connections on your battery terminals. A bad or loose connection will make your radio reset each time you start your vehicle. Other places you might look are hot wires leading to your fuse box, if you have an after-marked radio installed. In some situations, the hot lead going to your fuse box may be shorting out. If your tach is stuck, you have crossed wires under your dash, also a case that will happen if you have an after-market stereo installed.
Nov 15, 2010 | 2006 Ford F-150
I have a vauxhall zafira 1600(2001) i have replaced my in car audio with a CD240MPR/512, it will not let me store the stations can anyone help many thanks
This is normally due to the permanent battery feed to your radio is missing . Check the wiring and connectorsand fuses
Note: The main battery feed is via the Ignition Switch but the permanent battery
Jun 05, 2010 | Car Audio & Video
Looking for wiring diagram for 1988 escort 1.8 tdi. need to fit cd/radio existing wiribng just on chp block..
you need a volt meter and 9v battery. earth black contact from meter & then
  1. with ign off probe wire to find a live , thats the memory feed goes to yellow on radio
  2. with ign on probe wires that the constent live goes to red on radio
  3. when lights on probe wires thats the illumination feed (if fitted to car, but not used on many new radios
  4. then get 9v battery and with remaining wires pair and connect to battery, when speaker buzz's mark pair as they are ( ie front right rear left etc ) the speaker wires from the new radio are paired by colour ( one with black stripe with is the negative of the pair)
  5. there should be a ground/earth which if you cant find just hook one to the body/chassis
Jan 03, 2010 | Car Audio & Video
I have a 81 grand prix the radio wiring harness is not there thers just loose wires how do i fid the harness to hook the wires back up so i can add an after market harness and cd player
How to hook up stereo in 99 blazer ls what wires go where
Jan 02, 2010 | Car Audio & Video
Do you know the radio wiring colors for a 1996 jeep
you need a volt meter and 9v battery. then earth black contact from meter & then
Jan 01, 2010 | Car Audio & Video
Wires have been cut in my citroen saxo vts where the radio goes. i have a radio but as the cars original sterio loom has been cut out i am having trouble knowing what wire connects to what
based on not having steering controls if you have you will need a cit wiring diagram but the norm is
you will need a volt meter and a 9v battery,
test all wires with meter to fin a live with the ign switched off, ths is the live memory feed
the try again with the ign on, this is the switched live
there will be an earth/ground and light feed when you power the lights on.
when you do that to find the speakers
take a pair of remaining wires and place them on the 9v battery, work through the wires til you here a speeaker crakle, then continue till you find all speaker, that will allow you to hook up to a aftermarket unit,
or if you can get to a scrap car of the same year and type, cut the harness out and match up the wires
Dec 20, 2009 | Cars & Trucks
Looking for code for CDR500 ( vauxhall Zafira 2003)
Dear Sir,
We got problem to audio of zafira 2002. we need pin lock code for playing radio and CD player.
thank you for cooperation
Trisno
Jakarta-Indonesia
May 28, 2008 | Car Audio & Video
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
