Question about Dryers
Flavel emberglow takes ages to ignite then you have to hold control in for a while or it goes out
  • Dryers Master
  • 5,323 Answers
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Posted on Apr 26, 2015
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
Bosch aquastar a125b piezo wiring diagram
Piezo igniter only needs 1 wire to cause spark.
The other wire might connect to electronic gas control to report error, but brand type and age of product is not described in question.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene h
Mar 18, 2014 | Water Heaters
The self gas ignition stays on and keeps clicking.
Request manuals and parts lists directly from Flavel.
Nov 04, 2017 | Stoves Ovens
Flavel emberglow classic gas fire
No it should not. Soot usually indicates incomplete combustion and the air shutter may need to be adjusted. Intake and exhaust piping should also be checked for any obstructions.
Dec 22, 2013 | Heating & Cooling
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
Where is the battery compartment for ignition on a flavel sable 2 cooker
Take the bottom sliding drawer out of the oven, the battery box is on the right hand side, in the exposed space.
Nov 02, 2011 | Cars & Trucks
I have a flavel emberglow gas fire the pilot light works but when you turn the fire on it stays on for about 5min then goes out including the pilot light
From what you described it sounds like the Oxygen Depletion Sensor (ODS) may be partially clogged with dust, lint and/or pet hair. The ODS is a safety device, that shuts the system down if it detects that there's not enough oxygen for safe combustion. It can be cleaned with a can of compressed air with a straw nozzle (like you clean your computer with).
Remove the logs from the burner and carefully set them of to the side, out of the way. I should mention here, the logs have to go back in the exact same position and configuration that they were in, before you took them out. So, keep that in mind. Better yet, find your Owners Manual or take a picture of the setup, before you remove them.
Once you have the logs off the burner(s), use a vacuum that has a hose and brush attachment and vacuum the burner(s), the grate and any cobwebs you see in the firebox. After completing the vacuuming, look at the Pilot Assembly. Tank the can of compressed air with the straw nozzle attached and blow out the pilot tip with a quick blast of air. Now, log down the pilot from the tip. About 2/3rds of the way down, you will see a hole in the side of the pilot. That's the ODS sensor. Place the tip of the straw nozzle just barley into that hole and give it a quick blast of air. You may see debris come out the other side. Now, reinstall the logs on the burner, the exact way they were before you removed them. Light the pilot as you normally would and once it lights, hold the Control Knob in for 1 minute. Ease of the Control Knob and turn it to the ON position, Everything should not work as it was designed.
Take a moment to pat yourself on the back. You just completed what's known as "Annual Maintenance." Which should be done at least annually. Usually in the Fall, before you light the gas logs for the heating season.
Hope this helped to solve your problem.
Rich
Mar 02, 2011 | Heating & Cooling
After about 5 years with no problems, the emberglow vent free gas logs are not igniting. the gas is coming out as i can hear it, but the ignite switch doesn't have any effect. if i hold a lit lighter in...
Sounds like a bad pilot sensor called a Thermocouple. It is a copper tube that goes from the gas valve to the pilot assembly. It is the smaller of the two tubes. They are available at better hardware or farm stores. It is best to unscrew it from the gas valve and pilot assembly and bring it with you when you shop for one. It is something any mechanically inclined homeowner can replace.
Dec 03, 2009 | Desa International CCL3924PTA 24" LP Gas...
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Dryers Logo
85 people viewed this question
Top Dryers Experts
