Question about Cradlepoint Computers & Internet
No connection with 3g modem says contact INTERNET provider, but worked fine last week.
Just stopped working. log in, connect to wireless network no problem, but does not recognize modem like last week
  • Cradlepoint Master
  • 5,651 Answers
Try resetting!
Posted on Nov 09, 2014
Testimonial: "yes sure, I did reset, hard reset, login, setup, etc. When I do the windows trouble shoot, it says contact the internet provider, as it might need to be set up. That could not be true, as I've literally used this router for 6 years and the modem for the last 3 years."
  •  Mikey
    Mikey Nov 10, 2014
    The modem is not making an Internet connection......have you contacted your service provider to see if they have issues in your area?
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
  • 16 Answers
SOURCE: Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Posted on Aug 10, 2008
  • 8 Answers
SOURCE: TP-LINK WR642G Problems with wireless connection.
Is your wlan & internet light lit?
Posted on Sep 09, 2008
SOURCE: Asus WL-520GC wireless not working....
how to reset my asus router
Posted on Oct 07, 2008
dante777
  • 623 Answers
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Posted on Jan 27, 2009
Direct access through LAN cable internet was working fine. whereas while connecting through DLink(Dir 600) pages were not loading correcly. I tried Netgear modem it was working fine. What is the probl
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Aug 31, 2014 | D-Link Dlink Dir-600 Wireless Router...
My daughter works at home as a Customer Service Rep. for Generation Networks (Ancestor.com). She has a terminal from work and it is configured for her to work from home. She has done that for over a year...
This is only a problem with the firmware of your modem/router that you need to update it, because a network device like a modem and router that is working fine for severla years and suddenly stop working you just need to update the firmware of it and it should be working fine again, to update the firmware of the modem/router just need to call the manufacturer for that....
Hope that helps.........
Oct 05, 2008 | Computers & Internet
3G usb modem wont connect to internet through wireless router
Sure you can that. 1. you have new internet connection. need to configure the router according to internet connection type. it could be manually ..
2. set the wireless settings on the router again manually.
then try to connect the router.
If you need my help
the send me some information about the network.
1. when you connect your pc to modem what ip address you get.
2. what ip you get when u connect your pc to router. make hard wired in both condition.
and possible send me your email add.
Dec 23, 2012 | Computers & Internet
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Lenovo G550 running Windows 7 won't connect to internet. "Default gateway is not available" message displays. I have 4 Vista computers using wireless connections all functioning fine, but this...
Hello
Wow youve done almost everything here.How about the firewall? is it blocking any connections?
Next,Go to control panel,network and sharing center.Look and see if the pc or laptop in question is on the same network,meaning home or public.
Set all your machines to the same network.Either home or public.I do know this has been a win 7 problem.
Mar 11, 2011 | Lenovo G550-29583AU Notebook
My computer doesnt want it connect to internet,, appear the connection icon but when the page try to open , it cant do
Please follow the steps provided below:
Q: Basic Wireless Troubleshooting
A:
The following steps will help determine if the wireless card in the system is functioning properly.
IMPORTANT:
Please go through all the troubleshooting steps. If the wireless card is functioning properly, please check the network configuration. Acer America can not assist with configuring the network.
Before you start:
  • Make sure there is a wireless router or wireless access point.
  • The wireless router/access point is plugged in.
  • Refer to the owners manual to ensure the wireless adapter is on (you can turn the wireless card on and off by pressing a clear button)
  • Contact the internet service provider to make sure ther account is active and the network is connected in a way that supports their configuration.
If the computer was working properly at an earlier time:
If the laptop was working fine, do a System Restore which rolls the system back to the last known working configuration. System Restore is located in System Tools under Accessories. Here is a link to explain the use of this feature:
http://support.microsoft.com/default.aspx?scid=kb;en-us;306084
To find the wireless network:
1. Click on Start winxpstart%20button.jpg then click on "Control Panel."
xpmenu.jpg 2. In the Control Panel window, click on "Network and Internet Connections."
3. In the "Network and Internet Connections" window, click on "Network Connections."
networkconnect.jpg 4. Once in Network Connections, right-click on the wireless connection then select "View available wireless networks"
5. If the wireless network is a secured network, please refer to the manual of the wireless router to make it unsecured for the purpose of testing the wireless network.
NOTE: Acer does not recommend leaving a wireless network unsecured and is not responsible for data accessed due to unsecured wireless networks.
6. If the wireless network is listed, the wireless adapter is functioning properly. If unable to connect to the wireless router, go through "Before you start" at the beginning of this article.
Mar 05, 2011 | Acer Aspire 5100 Notebook
I can't figure out how to set up my wireless internet.
To setup a wireless Internet connection you need the following :- 1. You need either a cable or DSL modem with a wireless router or a 3G wireless modem that connects to a 3G wireless network. 2. You need to signup with an Internet Service Provider. The Internet Service Provider may also provide this modem at a cost. 3. The Internet Service Prodider will provide an installation instructions/CD as well as E-mail setup. Have you already installed the wireless card driver on your computer? Can you give me details of what you have already done in regards with setting up the wireless access.
Jun 14, 2009 | Acer Aspire 5610-4648 Notebook
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
My internet speed is slow.I connect it via bluetooth.
Internet broadband connection is much more faster because it is directly connected via physical connection from the modem (typical setup for home use). But now a days wireless internet can now compete with DSL thru a 3G/HSPDA network. In our country we can have a maximum bandwidth of 2.5Mbps using 3G wireless network.
Answer:
Yes you can speed up your connection using your phone as a modem but you need to consider some aspects.
  • your phone is a 3G capable phone
  • you have 3G network signal that an indicator "3G"can be seen next to the signal meter of your phone.
  • your network provider has 3G services.
What happen to you most likely is that your are connected using only a GPRS/EDGE. This is equivalent to a dial-up with maximum of 56kbps transfer rate. There is a great gap between the two if you compare it.
I already tested mine with maximum receive/downlink of 2,501 Kbps. I was really amazed.
Hope this things help you. If it does, please rate me.
regards,
-engrkoiled-
Mar 27, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Router
check you cable connections, try to check if you can go online wired to the router if you are connecting wirelessly. You can also bypass the router and connect directly to the modem to make sure its working.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
Top Cradlepoint Computers & Internet Experts
S. Pankratz
Level 1 Expert
Prashant M
Prashant M
Are you a Cradlepoint Computer and Internet Expert? Answer questions, earn points and help others
