Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
When I make a call the person on the other end can't hear me? On two of the phones Eco message next to the battery on the screen.
  • Patricia Bennett
    Patricia Bennett Nov 09, 2014
    What is Eco mode on phone?
Iphone 4 mic
Not sure if this is the same as your Problem, but
I once had a problem with an iPhone where the person at the other end was responding, but they couldn't hear me. I Think the rain got into the microphone hole on outside of the phone during a severe storm & I needed urgentt help cause of the rivers flooding around me. (NorthWest Oz).
Murphy's Law - a phone will always break down when you need it the most!
As a temporary fix, I simply switched over to the speaker phone. The other person could now hear me OK.
(Use the hands free switch on the screen to turn the speaker on)
The iPhone has 2 microphones and it appears that only 1 was functional. It uses the second microphone in it's noise cancelling circuit. I guess it compares one input to the other to cancel background noise.
Anyhow, the iPhone came right the next day after drying out.
Hope This Proves Helpful to Others as well
Mar 23, 2014 | Apple iPhone4 4G iPhone 4
I can't hear my call
Your phone is dying. Next your screen will go out. Get numbers off your phone if you plan on changing carriers
Mar 26, 2013 | Samsung Reclaim Cell Phone
I can phone a number and they can hear me but I don't hear it ringing at the other end or hear the person I have rung, any help please?
If you can fixed it, fixed it by yourself by replacing a new speaker.
If not please refer to the nearest mobile service to solve your problem.
Thanks for using FixYa!
Sep 27, 2012 | Sony Ericsson Cyber-shot C902 Cellular...
MY I phone got damp, everything works but the screen is dark very hard to see
Put in dry rice in warm airing cupboard for a few days. If not working carefully open and try again. Or try a hairdryer not too hot!
Jul 05, 2012 | Cell Phones
How do i turn off eco mode in panasonic cordless
You cannot turn off the ECO mode manually.
Intelligent ECO mode (select models)
Power consumption is automatically reduced when the handset is close to the base unit for extended talk time. Battery life on Talk is up to 13 hours when in ECO mode.
https://panasonic.ca/english/telecom/telephones/features.asp#eco
Jun 25, 2012 | Panasonic KX TG4021 Cordless Phone
On answering a call i can hear them but they cant hear me
I would delete all paired devices from the Parrot kit and delete the Parrot kit from your phone, then remove your battery from your phone for 5 mins, then repair as a new phone. If this does not work you have a microphone issue, check the wire is not trapped behind one of the trims.
Nov 21, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
"unable to charge" message & person on other end cannot hear me
Go to a skilled mechanic, request him to check the charger, the charging connector, the charging controller IC to solve the problem.
Supriyo DG
Jun 12, 2008 | Motorola Mobility RAZR V3
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
63 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
