I have xtl 500 model no L20QSS9PW1AN .audio is not comming.its audio interface board consolete is ok, spk is ok cables are ok I also re software but same condition .some fault is inside the main board pl halp me . This is motorola product.
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Nov 09, 2014
  • liaqat ali Nov 10, 2014
    My question is this that motorola radio set XTL-5000 with audio is not comming.speaker cables all are ok broblem is in cct. What I do?
Motorola radio set XTL 5000 audio is not comming spk cables are ok. Main cct board is faulty.whst I do pl help me
Check that you have the radio set to message trunking. it sounds like your in transmission mode.
Nov 10, 2014 | Radio Communications
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
SPK-VELO2 power supply unavailable
Go here: http://www.audio-unlimited.com/support and ask them. They have live chat to answer questions like this. If they can't supply you with a replacement you could ask them for the specs to guide you when selecting a supply. These include the current (in milliamps or amps required by the unit, and the size of power connector that will fit. Without this info no one could help you other than someone who is familiar with them.
Apr 13, 2013 | Cables Unlimited SPK-VELO2 Audio Unlimited...
HDD Upgrade
That model has standard IDE interface for hard drive. Don't think 500 GB or higher comes with that interface. The standard now is SATA interface for hard drives. Here is a lnk to the owner's manual for you model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx60_user%27s%20guide_en-us.pdf
You tell the difference between standard IDE and SATA in that the standard IDE interface uses a wide flat ribbon cable to connect to the drive. SATA uses a small thin cable as shon in the following link:
http://www.google.com/imgres?imgurl=http://www.cooldrives.com/lib/cooldrives/ultraflex-sata-cable-2.jpg&imgrefurl=http://www.cooldrives.com/24seatsaiiul.html&h=514&w=600&sz=35&tbnid=wGLj8F1otpnJYM:&tbnh=97&tbnw=113&prev=/search%3Fq%3Dwhat%2Bdoes%2Ba%2Bsata%2Bcable%2Blook%2Blike%26tbm%3Disch%26tbo%3Du&zoom=1&q=what+does+a+sata+cable+look+like&usg=__57zU4K_H2rpvq5AyZ41v_Ag4RTk=&docid=m3f9D21nEcMb3M&hl=en&sa=X&ei=NZQVUbrfDJD49gSd44CAAg&sqi=2&ved=0CFkQ9QEwBA&dur=81
Feb 07, 2013 | Dell Optiplex GX60 PC Desktop
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
DSC hookup
It appears to have a computer interface,It uses an RS232C Interface, a small D9 Socket on unit, you need a specially wired cable, to talk to your unit, with GPS software, it sends out NEMA codes to the PC. You also need driver, and software, software at the least. www.jeppesen.com/documents/.../FullCompatabilityListAug09.pdf software compatibility list above.
I looked but couldn't find a manual...
Apr 03, 2010 | JRC Plot 500F GPS Receiver
Please explain the difference between Intel ATX board D865GLCL vs. D865GLCLK.
Hello edk2,
Here are the diferences in the models of motherboards:
D865GLCLK: Video, Audio, Gibabit LAN D865GLCL: Video, Audio, 10/100 LAN D865GLC: Video, Audio
This means that the D865GLCL has the Fast Ethernet LAN Interface on-boardwhile the D865GLCLK has the Gig-E LAN Interface on-board. However, the D865GLC does not have an on-board LAN Interface.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 27, 2009 | Intel D865GLC/ D865GLCL/ D865GLCLK MB,...
No sound from speaker
Isolate the wiring, too. It's a binary problem. Should be easy. Or try running your suspected speakers on other channels to eliminate amplifier bugs.
Jan 02, 2009 | Onkyo TX-DS595 Receiver
Fans comes on for 3sec
Here are a couple of things...heres the Intel site about this board, with connections (with a very clear front panel drawing) diagrammed:
http://support.intel.com/support/motherboards/desktop/d850gb/sb/CS-013238.htm
and here is a page of pictures of this model board to compare to youre to make sure it is the same board:
Jun 04, 2008 | Intel Desktop Board D850GB Motherboard
Front audio connections
OK, let the speaker cable be your guide, its a for pin female connector, form there you should find your way.
let me know
Dec 15, 2007 | A-Top XBlade Mid-Tower Case
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
