Question about Samsung Digimax A40 Digital Camera
Why is my camera reading card error to all memory cards even without any memory card?
  • 179 Answers
When it can't find a card it might report this as an error. Try putting a card in.
Posted on Nov 09, 2014
  • 40 Answers
SOURCE: Memory Full Error
to use a memory card u have to check the manuel probably u have to buy an mmc card for storing pictures and videos as it is an sd card u have to first dormat it u can do it inside a mobile phone also
Posted on Jul 05, 2007
SOURCE: samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Posted on Jun 16, 2008
SOURCE: Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Posted on Dec 03, 2008
SOURCE: camera says my memory is full
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
Posted on Dec 12, 2008
  • 85 Answers
SOURCE: I just bought a new
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Posted on Aug 10, 2010
Testimonial: "Thanks, I didn't know that! Now I'm just annoyed at the store who sold me the 8GB memory card. Guess I'll have to save that one for later."
I got cannon power shot sx130 is it reads memory card error the memory card is not locked but the eject button is not working how to fix this problem. thanks
Try to switch off the Camera and restart it gain. Again, Sometimes, its due to some auto-run software running in the card which prevents that from ejection. You can try to even format the card in the camera itself. That may work also.
As a last resort, check up your camera and get that memory card removed out of your Camera.
Feb 16, 2015 | Canon Powershot SX130IS Black Digital...
My Canon says Memory Card error even with a new Memory card..what to do?
Some older cameras will only accept certain size memory cards and types. Some faster new memory cards may not work with your canera - check your manual
May 21, 2014 | Canon PowerShot SX120 IS Digital Camera
My camera read "card Error" when i put one in
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 16, 2010 | Samsung Cameras
Hello I have a Canon Powershot A540 camera. It is about 6 years old. I have used memory cards previously without a problem. I recently puchased two new memory cards and cannot use them. When I...
Hello and welcome to fixya
Since your camera is more than 6 years old the problem is probably related to SD/SDHC compatibility. You cannot use a card larger than 2GB in your camera.
In 2008 the SDHC format was introduced but even though it fits the SD slot perfectly , the camera's manufactured before 2008 does not have the capability to use the card and reads card error or other messages.
This is 9/10 times the problem you will have. If you have a card smaller than 2Gb with witch you are having the problem , please read the following tip a friend of mine wrote on the subject as it covers all the possible alternative problems you can encounter.
http://www.fixya.com/support/r4117096-card_locked_error_fix
Kind Regards
Andrea
Sep 27, 2010 | Cameras
I have a Kodak C330. The memory card reads full
Having gone over a month without a response, I assume this is no longer a problem.
Apr 21, 2010 | Kodak EasyShare C330 Digital Camera
Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
Feb 17, 2010 | Pentax Optio S5i Digital Camera
I bought a new memory card and when i insert it I get the message: memory card error. how do i correct this? thanks
Some cameras will not support the later versions of the SD v2.0 released after June 2006 (secure digital mutilmedia card) memory cards that are on the market/
First check the size of the card in (MegaBytes) some older cameras will not even read a SD v1.x 2MB card but will read the smaller 1MB size.
Check for compatibilty with SDHC (Secure Digital High Capacity, SD 2.0) on your camera even though it will fit as it has the same form factor (footprint) as the SD v1.x the camera is not set up to read it and will throw and error.
I suggest that after you have checked all this try and get your money back.
Sep 28, 2009 | Cameras
Is there a size limit for the memory card for the SD630. I put a 4 GB one in it, and it say memory card error
This camera only supports up to 2GIG or memory card so that's the reason why the 4 GIG wont work with it....
Jul 31, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Samsung Digimax A40 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
