Question about Saws
I've got Mcallister mms255sl sliding mitre saw keeps tripping the main fuse as soon as u pull the trigger I've tried different saws on the same setup n all fine it's just this 1 that trips it everytime any suggestions
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 179 Answers
Quite possible that you have worn out the circuit breaker with multiple trips. Try another circuit that is on a different breaker.
Posted on Nov 09, 2014
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Posted on Mar 01, 2012
Tooltec 1800w mitre saw all I did was change the blade and now the saw is dead
Does the motor hum when you pull the trigger? If so, check that the push tab for securing the shaft from turning while changing the blade is pulled out all the way. Sometimes fine saw dust can get inside and prevent the spring from pushing the tab back out all the way. If there is no hum, check the power source.
Mar 23, 2017 | Blade Saws
Coord is fine tried many differant outlets, bu as soon as i plug it in the circuit braker trips.Any help about where the short is?
65 AMPS? That's drawing a LOT of power.
Is it tripping the breaker even before you pull the trigger?
If yes, I would use a continuity meter to start checking the various components. In particular, see if the switch is stuck in the ON position.
Unless you are experienced in tracking and performing electrical maintenance problem solving, this may be a situation best left to a repair shop.
Cheers
Mar 13, 2016 | Dewalt DW303 Heavy Duty 65 Amp...
Mastercraft mitre saw
with regards to the stanley power stapler gun............replace the micro switch
Dec 02, 2013 | Hand Tools
Problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Jun 04, 2012 | Dewalt Tools & Hardware - Others
Macallister mitre saw sparking
Feb 26, 2012 | Saws
I have the old model c10fsb mitre saw but need to replace the two parts of the handle & the trigger,where would i get them ?
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
Mar 14, 2011 | Hitachi C10FSB 10" Sliding Dual Compound...
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
http://servicenet.dewalt.com/
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
Ryobi compound mitre saw sliding 10" laser line is 1.5 mm out to the cut is there any way to adjust it
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
Apr 17, 2009 | Ryobi Circular Saw W/Dual Laser
Saws Logo
167 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
