Question about Microwave Ovens
Why does my halogen oven only work when the top is turned upside down?
I have changed the bulb, but the problem remains. If I take turn the lid over the oven starts up but when I place it on the bowl it stops working!! I couldn't see any bad connections when I had it apart.
    Problem Solver:
  • 18 Answers
You have a sensor in upside down. Usually the lids only work when down, switch off when not - go back over what you took apart and see if there is something you could have got 180 degrees wrong.
Posted on Nov 09, 2014
Testimonial: "The problem was there before I took it apart, only the bulb was changed and nothing else was touched."
SOURCE: Whirlpool GMC305PD -- Thee beeps and won't start
Worked great!! I bought a new fuse for $4.50 and replaced it and the microwave works again....light is still not working but I'm ok with that!! Thanks!!!!
Posted on Mar 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Microwave oven night light
This is a bad connection or a shorted dimming diode on the control circuit board.
We regularly repair these controllers for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 26, 2008
THENTHEREWER
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
  • 3 Answers
SOURCE: Microwave oven stopped working
OMG!!! This was perfect. I had the same problem. Timer was on but the fan nor the table turned. Just when I was about to take the thing and chuck it in the trash, I thought I'd give the above method a try. I turned the microwave on, and nudged the door sligthly upwards.... miracle! it started to work. to make it permanent, I took the door off (the cap on the inside of the door, on the upper hinge needed to be removed with a flat head screwdriver, very easy, just pry it off). Once I took the door off, I placed a small washer on the bottom hinge to raise the door slightly. Put the door and hinge cap back on... and Voila! The microwave works now. Thanks for the help guys...
Posted on Jun 01, 2010
  • 906 Answers
SOURCE: Grilling Halogen & Quartz Replacement Bulbs and Paint coming off handle
good day,
hope this link below will solve your problem.
grilling
Posted on Aug 05, 2010
Oven light jvm1540dn1ww
# 1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.# 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.# 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.# 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.# 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.# 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
Regards.
Jan 28, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Changing the light bulb
Regards.
Jan 05, 2012 | Panasonic NN-H264 Microwave Oven
How to replace lightbulb inside microwave
  • 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
  • 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
  • 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
  • 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
  • 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
  • Oct 27, 2011 | GE JVM1860 Microwave Oven
    Jvm2070sk02 interior light does not come on can the bulb be changed?
    HELLO.
    When you open the door on your microwave, it sends an electrical current to the halogen lightbulb mounted inside the microwave. The signal turns on the light and illuminates the inside of the microwave.
    In addition, while cooking your food, the light illuminates so you can monitor the condition of your food while cooking. While the bulb generally lasts a long time, when it burns out, you must service your microwave.
    THANKS.
    willing to help on more question.
    Sep 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
    That's covered on pages 35 & 36 of your owner's manual.
    If for some reason you don't have yours, you can download it here.
    Cooktop Light/Night Light
    On models JVM1850, JNM1851, DVM1850 and
    EMO4000, replace the burned-out bulb with a 120 volt,
    40-watt incandescent bulb (WB36X10003), available
    from your GE supplier.
    On models JVM1870, JVM1871, JVM2050 and
    JVM3670, replace the burned-out bulb with a 120 volt,
    20-watt halogen bulb (WB36X10213), available from
    your GE supplier.
    To replace the bulb(s), first disconnect the
    power at the main fuse or circuit breaker panel
    or pull the plug.
    Remove the screw at the left edge of the light
    cover and push on the right edge of the cover
    to open.
    Be sure the bulb(s) to be replaced are cool
    before removing. After breaking the adhesive
    seal, remove the bulb by either gently turning
    (for models JVM1850, JNM1851, DVM1850 and
    EMO4000) or pulling straight out (for models
    JVM1870, JVM1871, JVM2050 and JVM3670).
    Replace with the same size and type bulb.
    Raise the light shield and replace the screw.
    Connect electrical power to the oven.
    Oven Light
    Replace the burned-out bulb with a 120 volt, 20-watt
    halogen bulb (WB36X10213), available from your GE supplier.
    To replace the oven light, first disconnect the
    or pull the plug.
    Remove the top grille by taking out the screws
    on top of the grille that hold it in place and
    sliding the grille to the left (opening the door
    makes grille removal easier).
    Next, remove the light cover.
    On some models, the light cover is located
    in the center of the top opening. Remove the
    screw that secures the light cover and lift the
    cover off.
    On some models, the light cover is located at the
    left of the top opening. Lift the cover off.
    Pinch the clips that hold the light socket in
    place and lift the socket out.
    Remove the bulb from the light socket by
    pulling straight out. Replace with the same size
    and type bulb, then replace the light socket and
    cover.
    Replace the grille and screws. Connect electrical
    power to the oven.
    Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    How do you change the halogen lights. The space around the bulb is very, very tight making it virtually impossible to turn the light bulb....any suggestions
    They make a suction cup like thing on a stick that you stick up there and then turn out the lights with it... they sell them at Home Depot and Lowe's...
    heatman101
    Jan 04, 2011 | Microwave Ovens
    How do i change the bulbs on a jvm1870sk03 microwave
    That's covered on pages 35 & 36 of the owner's manual here.
    your GE supplier.
    or pull the plug. *
    to open.
    Oven Light
    GE supplier.
    or pull the plug.
    cover off.
    cover.
    power to the oven.
    * If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
    Apr 25, 2010 | GE JVM1870 Microwave Oven
    GE Spacesaver JVM 1870 carousel doesn't turn, doesn't heat
    We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
    This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
    This can often also affect the exhaust fan operation and other operations, too. The lights and fan can be inoperable or stuck on too.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
    Feel free to contact me directly.
    We're happy to help you and we'd appreciate your thoughtful rating of our answer.
    William E. Miller
    prototech@usa.net
    Jul 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
    GE Profile XL 1800
    It's a little more complicated than Leo2 suggested but the general concept is correct. *NOTE: Turn off power to the microwave first before servicing it!
    At the top of the microwave there are three screws.
    Remove the three screws and slowly pull down from the top to get the plastic airvent out of your way.
    You will notice a plastic vent with two screws. Remove the forward screw and then pull from the top of the vent to access the rear screw. Now you have access to a metal plate above the fan assembly. Remove the screws at the leading edge to lift up the plate. You don't need to remove it, just lift it up!
    Now you have access to the metal box over the lightbulb. Squeeze the box and the box with the light bulb inside come out as one unit. You'll know you have the correct bulb as it is attached to two white wires. Remove the bulb. Should be a halogen 120-130 volt with 35 watt brightness. Remember, halogen bulbs should never be handled with your bare hands. The grease from your fingertips heats up and the bulb burns out prematurely. Always handle these bulbs with rubber or cloth gloves. They are expensive little sucks ($7.79 at Home Depot) so handle them with care!
    Good Luck ...
    Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Interior Light
    The interior oven light can be accessed in the following way:
    1.Open door and remove the top grill via the 2 screws along the top edge.
    2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
    Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
    Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
