Whirlpool Duet checked filter removed gunk. Struggle to spin and clothes are still wet.
  • 3 Answers
Possible worn motor? How old is the machine? Is it overloaded? Try lighter loads. Try to spin with the machine empty to test the motor.
Posted on Nov 09, 2014
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Display read suds, cloths wet and waher will not spin.
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer spins but water does not discharge. spin
Tip machine back and remove the bottom panel, 3 screws. You will then see a large tube at the front, unscrew in a counter clockwise direction, and remove. Clean pin trap lubricate o ring and replace back into recepticle
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer will not drain fully sometimes clothes are wet and others it spins fine?
if the drain time exceeds eight minutes,the water valves are turned off and the F/02 is flashing.press pause/cancel two times to clear the display.this is a long drain problem.check the drain hose and make sure it is not plugged or kinked.unplug washer or disconnect power.check the electrical connections at the pump and make sure the pump is running.check the drain pump filter for foreign objects.plug in the washer,if the above does not correct the problem,replace the pump.
Jan 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The clothes are still very wet when the cycle is done, and there is a little water sitting in the bottom of the machine. Is something wrong with the spin cycle?
does the drum turn on high spin if it does is there a low and high for the spin also check the filter which should be located at the fort bottom of the machine it might be blocked
Oct 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht, motor running but nothing happening, says 48 mins to go, cancel does not work. Have unplugged but will not reset. Left over night unplugged, stiil not reset. Cannot open door to even get...
Our Duet washer (5 years old) would not pump the water out, and would not spin. It displayed no error codes. Tried reset, would cancel but still not work. I started disassembly (found the Whirlpool maintenance/ repair manual on line to refer to); everything seemed to check OK. Cleaned filter, fortunately the washer sits on a pedestal drawer as the washer had at least 3 gallons of water in it I had to drain into a bucket. As I went through the diagnostic test sequence found in the repair manual it was apparent that although the pump had power and made noise, no water pumped out. I removed the pump assembly and found the remains of a small plastic baggy fouling the pump impeller. It was left in a clothes pocket and run through the washer. No idea why the filter basket didn't stop it. Pulled baggy out with needle-nosed pliers and presented it to my wife (her baggy). Reassembled and all works great. No cost, actually made 1 cent on the penny found in the filter basket. You need a Torx screwdriver to access most of the panels. Reason for not spinning was the massive weight of wet towels and water sitting in basket.
May 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer & the clothes will not spin out the water when the washer is done they are still soaking wet?
possible that with the machine not draining, its not going to high speed spin try this:
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer, clothes dripping wet
set it for a drain/spin cycle and watch it 12 min. doesit sound like the pump is kicking on???? if so is it removing water??? (you should hear it or see it exiting out hte drain hose.) next is it actually spinning at full speed by min 7 in the display it should start ramping up to the final full rpm spins, usually faults out if there a problem with unit itself, otherwise its a user end issue. you ARE usinf HE detergent right? not just a little less of regular soap! although it sounds good HE detergent actually designed for yuse qith the frontloading products, too much suds causes , no hide speed spin aas well as a SUD in the display
Mar 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
