What causes my Samsung touchpad remote control batteries to finish in 3 days
My remote used to work well but of late doesn't respond consistently (easier to change channels manually from the back of the tv) and batteries when new will not last 3 days.
    Scholar:
    New Friend:
  • 88 Answers
Dirty contacts inside battery compartment, or inside on circuit board , use your own judgement on this. If it was mine look along the seam and find the small detent tabs that hold upper and lower halves together separate halves and clean board with alcohol. Check U TUBE under how to clean remote, good luck Bret
Posted on Nov 09, 2014
SOURCE: TV not responding to Remote
LG had a run of bad diodes in some of there lcd tv's recently but have been good about fixing those effected units. Tv's will not respond the remote and may turn on and off by itself and cycle thru channels.
Posted on Dec 12, 2007
  • 718 Answers
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Posted on Mar 16, 2009
  • 4 Answers
SOURCE: LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
Posted on Jan 23, 2010
SOURCE: TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Posted on Mar 15, 2010
Testimonial: "Thanks I'll be checking them."
SOURCE: Hi, my remote control is
It's a common problem with this model. You must change the IR board. This is very easy to do. Remove the back panel of the tv and unscrew/unplug the original board located where the power button, volume/channel, etc is and plug the new one. I bought my IR at Ebay, but sadly have to say that it was not working. Watch out these bargains, :-(
Posted on Jun 07, 2011
Samsung tv has never responded to the remote control
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Feb 15, 2014 | Samsung TV Remote Control
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Dot s touchpad not responding
Use an usb mouse to select control panel and then select device management. From there you need to select the mouse and from there select the mouse and right click on it. Select to uninstall the device. Then close all screens and shut down computer. Unplug the usb mouse and restart the computer. If after it completes loading and it doesn't work the you will need a new touch pad. But if it does work it means windows had an corrupt update which caused the problem. Thanks Igor!
Sep 29, 2012 | Computers & Internet
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Volume on Remote powers TV on and off?
This unit has upgrades available for this set. I am not at my shop now, but, I think the problem you described is usually cured by this upgrade. The set is under warranty, contact: 1-800-Samsung for a local servicer. If you need additional help, respond to this post and I'll reply.
Aug 26, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
