Question about Samsung Cell Phones
How to get PUK for slot 1 - Samsung Cell Phones
Samsung duos PUK slot 2 code how to unlock
PUK lock (Personal Unlocking Key). It's a security feature on most mobile devices that protects your SIM card data and unique for SIM card.
May I suggest that you contact your sim network provider as they are the only one who can provide you the PUK codes. Once you done the PUK unlocking you can use the unlock code.
to use any neywork sim
Official Samsung IMEI Permanent Unlock Important Select the Current...
Jun 09, 2018 | Samsung Cell Phones
Got the phone locked and it says enter puk code.anyone with any ideA? Also trying to hard reset my phone and nada. I hold down vol and power and nuthing changes. Please show me umx maxquartz v351
Puk code usually comes from retailer, or it takes a SIM card. Puk could b on box, or Google search service provider & type of phone. From there u might get it offline or it might shoot u to YouTube, in which u can possibly , get it and instructional video. If all else fails, call the service provider and let them know u bought it used. If it isn't reported lost or stolen, they will walk u thru the unlock. Typically the PuK is SIM card involved, open the back, take out the battery and find empty slot that reads SIM, not SD or memory card slot.
Aug 08, 2015 | Cell Phones
"Sim2 is now disabled enter PUK code to continue" message. What to do?
The sim which was there in sim 2 slot call the customer care of that service provider from other mobile and ask for puk code
Jun 04, 2015 | Cell Phones
Cara membuka kode puk samsung gt-C3312
phone lock puk slot samsung GT C3312
IMEI:352098/05/177738/9
IMEI:352099/05/177738/7
Jul 25, 2013 | Samsung GT-C3312 Cellphone - Unlocked...
WHAT IS THE PUK CODE FOR SLOT 2 OF SAMSUNG MOBILE
ask the PUK code to your network provider. After going through some procedure they'll give you the code
Jun 22, 2013 | Samsung gt-c3322 quad band dual sim...
Lupa kode kunci sim pada hp samsung gt-c3312
kode konci sim hp samsung gt-c3312 ime 352098051690103
Feb 23, 2013 | Samsung Cell Phones
Where to enter the PUK no once the SIM is inserted in the samsung champ mobile
For Insert Sim:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
For Puk code:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Oct 29, 2010 | Cell Phones
My touch sim card puk locked
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Sep 09, 2010 | Cell Phones
I need the puk code for my nokia 6230
puk code is provided by your service provider itself, call your service provider means the one who provides you the mobile phone connection.
the following details are essential for the same
1) which mobile phone number the sim was carrying which was last put in your mobile phone , which caused the puk code.
2) security details of the person on whose name the sim card is issued , like the name, address, birth date etc
3) mostly if u have been provided with a MIN number at the start when taking your mobile phone services, you could navigate through their IVRS to the spcific slot and put down your mobile number and the puk unlock code will be provided to you.
4) Call up the help line number of your respective service provider and they should help you out as the PUK code is service provider specific.nothing to do with the manufacturer of the mobile phone, but it is specific to the SIM card.
Apr 07, 2008 | Nokia 6230
Cell Phones Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
