Question about Pentax Optio Cameras
Pentax Optio E20 will not turn on.
My Pentax Optio E20 will not turn on. With new batteries when I press the ON/OFF button, I get a blink green on the power LED, but nothing else happens (the lens does not come out and the screen does not turn on). Please help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
Posted on Feb 06, 2015
3 Suggested Answers
svenby
  • 66 Answers
SOURCE: Optio M20 Camera: Press on/off
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Posted on May 30, 2008
  • 11967 Answers
SOURCE: Pentax Optio S5z \ Lens will not close
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 14, 2010
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Camera wont turn on!! help!!
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Jun 19, 2009 | Pentax Optio T20 Digital Camera
Won't turn on, only flashes a light
use rechargable minnimum 2500mah batteries -----solved
Nov 05, 2008 | Pentax Optio E60 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Dead?
Have exactly the same prob, my camera worked for 3 years without any probs, except that the alkaline batteries didn't have a long life...tried rechargeable batteries as well, but since three weeks ago it simply says, "batteries depleted", nothing works, tried everything...sending it to Pentax after the warranty is over is far more expensive than buying a new cam...really sorry for that, but don't think I gonna buy a new Pentax again...
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Optio S4i - Freezing problem on green switch
I don't know for sure, but it sounds like it could be a memory card problem. Have you tried it with another card or no card at all? My S4i froze up completely from a bad sd card. The green power button would light up, but nothing else would happen. Pentax recommends Lexar or Panasonic sd cards from what I have heard. My new Lexar card hasn't had any issues.
Sep 08, 2005 | Pentax Optio S4i Digital Camera
Cameras Logo
81 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
