My Scepter X32 TV screen got smaller, I was watching HD tv and everything was fitting onto the screen. Then I moved the TV a little bit and it changed to not fitting everything. Any idea how to fix?
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
Do a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 09, 2014
  • 3 Answers
SOURCE: my 47 in vizio lcd tv. the zoom/widescreen
the LCD TV is overheating. Solution A) allow air circulation. B) set up a small fan behind the TV C) once the set is cooled down save your preferences
Posted on Apr 05, 2009
  • 3 Answers
SOURCE: PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Posted on Jun 05, 2009
  • 267 Answers
SOURCE: vertical purple lines appear when watching tv but not dvd
You unit should be under warranty. contact the manufacture for the nearest authorized servicer.
Posted on Jun 26, 2009
  • 10 Answers
SOURCE: Scepter X37sv-Naga LCD
The Sceptre TV do use the Sony codes. However, the cheap universal remotes do not have the buttons needed. The Volume Up/down and channel up/down are controlled with the circle of buttons (arrows) in the middle of the remote.
You can get an OEM remote from Sceptre. They still have them available. Sceptre is in California.
Posted on Aug 09, 2009
roety
  • 585 Answers
SOURCE: Red line on screen, Plasma TV help.
Hi my name is Eric,
I hope I can help you with your issue ,
If the lines are there on every input then you have a bad panel (screen). The panel is the front screen section, if you could get one a new panel would cost more than a new TV. If the line is only there with the cable box then its just a bad box (I've seen the pace box do this)
If I have helped you with your issue please click accept.
If you have more questions you can still respond
Thanks
Eric
Posted on Sep 26, 2009
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
Hau do i move the picture sidles
Not enough information...
What type of tv and model etc.
One thing you should be aware of.
If you do not have HD tv...say direct tv
then you maybe stuck with a smaller picture.
Example:
If I run my direct tv HD I get a full picture but, if
I am running it in a non HD channel...the picture
is alot smaller with the black sides and top.
The other option is on your remote you should
have buttons to control stretch etc.
Use those and see if they help.
As far as dvd"s go...make sure your not using
the letterbox versions...full screen versions should
give you ...well...Full Screen.
good luck
Jan 26, 2011 | Televison & Video
I have an HP G60-117US Notebook PC. Can you tell me how to connect it to my Sony HD TV so I can watch a movie.
Use an HDMI cord to connect the two together. On your Sony remote click the TV/Video button ( also called input button) slowly until you see your desktop screen appear on the Sony TV. Your desktop screen will probably be smaller then the TV screen and will be a duplcate to the computer desktop screen. That might not be acceptible to you. You will have to change the resolution to the recommended 720p or 1080p to fill up the TV screen. The pc will recognize the Sony monitor (TV) as a second monitor. You could change it from duplicate screen to seperate second screen.
Oct 03, 2010 | HP G60-120US Laptop
Scepter X32 LCD High Definition telivision. Just
Yes it's dead; the power supply in these tvs do not have much stamina;
Due to the fact that their are no provisions for removal of heat. TV does not
have enough fans because customers don't like the noise and, the power supply surge caused by turning a cold set on and, off is not addressed by the manufacturer.
That is why the sets have only one a year warranty.
The choice you have is: repair the power supply or, replace the power supply
unless your set is under warranty.
Jul 30, 2010 | Sceptre X32BV-Naga 32 in. LCD TV
Good evening, I've gone through the manual and I can't get my TV to show 100hz (always 50hz), also on some channels I cannot get the picture to fit the screen (it's 32''). Any help would be greatly...
Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
Mar 15, 2010 | Televison & Video
Why does my 32 inch Toshiba keep changing screen format sizes ?
its not your tv. its the program you are watching some show hd picture that fully fit your tv. some still dont have the format for widescreen flat panel tvs. its still
Aug 28, 2009 | Toshiba 32A33 32" TV
Problem with fitting full picture on my screen.
You might need to change the format on both the tv and on the device that is outputting video. Also make sure you are using proper cabling if you have an hd receiver and are only using standard definition cables you might get smaller picture.
Nov 08, 2008 | Televison & Video
Static line
it might sound strange but i think the screen has dropped. I have seen this happen before, is it just one line or 2 as the screen is fitted in the shield, its held by a thin rubber sometimes it can drop when the tv is being moved about or in a lot of vibration like moving it about in a car. now this may sound strange but the last time i fixed one i used 6 match sticks and clean them up and put them in the screen housing and it keep the screen in place after that. but beautiful when removing the screen case as you can inadvertently damage the screen, the screen is only a thick as a bit of cardboard. i suppose you could even put the tv upside down on the bed or something soft and wiggle the screen back into place. this would not damage thew tv and you will not have to take it apart.
Jul 03, 2017 | Samsung HP-R5072 50 in. Plasma HDTV
To make screen clearer.
Are you using the original remote control...Reg TV doesn't fit your screen because it's not filmed in HD...But it should be clear but you have to watch it smaller... Usually big screen tv's will have a black trim around the picture...And zoom cuts off some of the picture..Some tv's have wide, cinema and other options...Your TV might just have zoom
Nov 11, 2017 | Hitachi 46F500 46" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
