My luxor keeps switching itself off and switching itself back on
After watching Netflix i tried changing the channel then it started switching itself off and back on every few seconds and always remains on the same channel and cannot be changed
    Top Expert:
  • Televison & ... Master
  • 75,404 Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 09, 2014
  • 33 Answers
SOURCE: The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Posted on Feb 19, 2009
  • 14 Answers
SOURCE: While trying to change channels, my t.v. displayed
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Posted on Apr 05, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: My Samsung LNT3253H LCD TV has suddenly started
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Posted on Sep 05, 2009
  • 127 Answers
SOURCE: My Philips LCD TV just changes channels by itself
it could be one of the buttons to change channels is jammed
Posted on Jul 13, 2010
gopakumarg43
  • 75404 Answers
SOURCE: my samsung tv keeps changing channels by itself
Check and replace its main system control memory IC. It is faulty. If you wish to get more details, check this link.
Posted on Mar 31, 2013
How do i install nexflix on to my tv
What type of TV do you have? If you have an HDMI input on your, TV then the easy way it to purchase a $35 Chromecast Device from Google Store. Netflix is an available app. See attached link for details. :)
Jan 29, 2018 | Computers & Internet
Luxor TV won't connect to preset tv channel apps. It keeps saying it needs to be connected to an aerial but it shouldn't because these apps should work through the wifi. Help please?
Did you get any advice elsewhere. My Luxor tv is doing the same thing. I don't have aerial input. Hence why I bought a smart tv. Netflix and YouTube are fine.
May 26, 2017 | Luxor Televison & Video
I have a luxor smart tv and netflix has gone from the home screen. Does anyone have any ideas as to how to get it back? Nf said to get a code from Luxor? Anyone have it?? Please n thank you!!
My smart TV has an app store to download more apps. If your TV has the same, you can go into there app store and download Netflix again.
Apr 03, 2016 | Luxor Televison & Video
My Netflix app has gone from my Luxor tv. It was there a few days ago How do I get it back. I have searched but it just says no app
Go to the "app store" associated with your tv, look under movies, and then reload the app. Put in your password and you are back in business.
Apr 01, 2016 | Computers & Internet
Roku is connected but when I try to select a channel from my menu it fails then if I go to settings it says that it's not connected. over and over again. This is my first setup. I have not watched an
I had a similar problem with Netflix on my Roku last night.
I had to remove the channel, Add the channel again, and resupply my email address and password for Netflix and it started working, again.
Other channels, it may give you an access code and an email address where you have to enter the code.
Mar 02, 2014 | Motorola Mobility ROKR E6 Smartphone
I want to watch netflix on my proscan tv, but I've put the tv on every channel and netflix doesn't pop up
it could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
Nov 29, 2013 | Proscan Televison & Video
Netflix watch mobvies
To watch Netflix movies, go to the Wii Shopping Channel and download the Netflix channel. Once it has finished, start the Netflix channel and follow the instructions there. Enjoy!
Jun 18, 2011 | Nintendo Wii Console
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
Televison & Video Logo
Top Televison & Video Experts
