Question about Vacuums
When do you start brushing a british longhair cat
What age do you start brushing
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
I would wait until you are at least 15 years old. Before that you may not really understand what brushing a british longhair cat is all about.
Posted on Nov 10, 2014
What is a good vacuum cleaner for cat hair, kitty litter, dust, and people hair?
I would by this vacuum it one of the best buys around I fix vacuums for a living this is a good vacuum FB MMPWCF4 Fuller Brush Mighty Maid upright Vacuum with Carpet Floor Switch
Dec 22, 2015 | Vacuums
My Rooma 500 series, when I press the start button to go....it sounds like it wants to move forward and the sings a song and doesn't move
I agree with the previous poster, every time you run Romba, you have to empty out the dirt compartment, take the beater brushes off and pull the hair, lint and thread off the brushes (if you use a cat or dog brush this works fantastically) and remove the lint that's wrapped around the ends of the beater brushes. Every other time, you need to remove the thread and hair wrapped around the rotating brush (sometimes you need to remove the Phillips head screw holding this on and really clean it out). Finally the rolling ball wheel needs to be popped out using a narrow, small screwdriver and all the stuff trapped in there removed.
Feb 23, 2015 | iRobot Roomba 560 Robotic Vacuum
Hi my name is Sapphire. I have a dyson DC24. The roller bar keeps cutting out, I can't depress the reset button properly and so it won't start up again properly without me trying for ages. The brush bar...
One possibility is a failing reset button, Another option is a bind causing excessive energy to spin it. This will cause the reset button to trip. Check the bearings in the motor and brush roll.
Nov 09, 2014 | Vacuums
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
How to change motor brushes on mile cat and dog
The first step is to remove the cover and pull out the motor at the casing of the unit.you can see the carbon brash when the motor is out of the casing.Just remove the spring and pull out the carbon brash and replace new carbon brash.Then return back the motor to the casing.Thanks...
Aug 21, 2011 | Miele Cat Dog Plus S511 Bagged Canister...
The rotatory brush stopped turning after sucking rug fringe onto it. The belt looks fine. The suction is fine.
Found on website "dysoninfo.com"
A problem I have run into a couple of times at home, generally when I am cleaning the bathroom, is that my Dyson brush won't turn. First off I would say be sure to check that you haven't pressed the button that turns the brush on and off, as silly as it may seem it may actually be the case. But if it isn't follow the steps below to clean your brush and get it working right again.
First and foremost always unplug your Dyson before you start any sort of work on it. Next grab a seat on the floor, yeah park your butr on the floor it will be easier because you won't be trying to lift your vacuum up to you. Now take a look at the brush bar to see how much hair and debris is caught in there. If there is very little then you probably don't have much to worry about and you can press the brush reset bar on the side of the vacuums head and your problem with they Dyson brush not turning in fixed. However if you are like me and you find that your cat, dog, and wife's hair are wound pretty tightly around the brush head you will need to take some time to pull in out of there as it is probably what is restricting the motorized brushes movements. Once you are finish you can also press the button on the side of the vacuums head. Now stand the vacuum and yourself back up and go plug it in. I bet that if you cleaned it out your Dyson brush will turn as normal.
Mar 20, 2011 | Dyson Vacuums
Took Roomba apart to clean and now the pick up brushes start and stop during cleaning. The vaccum is clean but will not constantly spin. Runs great but pick up brushes start and stop. Is there a number...
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
Dec 02, 2010 | iRobot Roomba 530 Robotic Vacuum
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
We have a Eureka Chinese p.o.s, model 6831. The brush roller won't turn, appears to be plugged with cat hair dang long hair cat. I cannot figure out how to remove the cover without breaking it after...
There are a couple of tabs on both sides of the top housing that need to be unlocked by using a flat screw driver, then the top will come off. The u shaped collar on the tube will then give way to take the roller brush out to clean.
Jan 01, 2010 | Vacuums
The brushes are not rotating - checked the belt no problem - what else could it be?
Assuming a drive pulley is not loose and the motor turns, try turning the brushes by hand. If they require much effort they may be jammed by dirt. My cat is a constant culprit!
Jul 18, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
