Question about Sewing Machines
Empbroidering does not work.
When I attach the embroidery attachment it does not answer for the meny, I cannot select the pattern like to sew. The thred is plinking and nothing else happens. I have tried all I can. I have several card. I've tried all of them. Nothing works
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Call company.
Posted on Nov 26, 2014
  • 185 Answers
SOURCE: problem with trac feeds
When you drop the feed dogs on most modern machines they do not return to the up position until the motor rotates one full turn. Your feed dog will then be up and ready to use.
Posted on Feb 28, 2008
SOURCE: Baby Lock Embroidery Sewing Machine
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Posted on Sep 30, 2009
  • 1116 Answers
SOURCE: Will the Brother ES2000 sew a buttonhole without
Have you made sure the buttonhole lever is in the buttonhole tab?
This tutorial will show you how to make a zig-zag buttonhole - http://www.ehow.com/video_4433258_making-hole-using-zigzag-stitch.html
The demo is a little sloppy. I stitch into the ends and I set the stitch length to zero when making the bar tacks across the ends. It takes a little practice.
I hope this helps.
Posted on Mar 07, 2010
Testimonial: "This is how I make button holes without the attachment. I thought maybe the machine might have a setting that would follow the diagramed design witho"
justinbur167
  • 257 Answers
SOURCE: I have a Husqvarna Designer
Hello Kimrasue,
I understand that you are having a problem with your Husqvarna Viking Topaz 20. I would suggest that you contact Husqvarna at 1-800-446-2333 as this machine carries a 20 year warranty you will need your model and serial number. Anything you do to fix this machine may void your warranty. They will also locate the nearest service center for you.
Thank you for choosing FixYa.com
Justin
Posted on Apr 25, 2011
SOURCE: I have a Brother innovis 4000d sewing and embroidery machine. The embroidery pattern l am trying to sew has worked really well in the past, but now when it starts to sew it is not picking up the botto
try changing the needle
clean under the needle plate & in the bobbin area for loose threads or lint
rethread the machine top & bobbin
Posted on Apr 27, 2012
Testimonial: "Thanks so much for the help :)"
My machine does not recognize that the embroidery unit is attached. It keeps saying attach embroidery unit. Has anyone had this problem
What make and model of sewing machine do you have? I have seen this problem with a Husqvarna Viking Designer I (or similar older Viking machine). In that case, the problem was corrosion on the contacts between the embroidery unit and the sewing machine. The solution was to use an electronic contact cleaner to clean the contacts; this is one product: http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0 . Make sure that the machine is unplugged. Spray the contact cleaner on the contacts. (In some cases, you should then connect the embroidery unit to the machine and remove it a few times.) Allow the product to dry before you plug in the sewing machine again.
In another case, the solution was actually easier. The owner had two similar embroidery machines. She managed to mix up which embroidery unit went with which sewing machine. Neither embroidery unit could be properly seated on the machine that she attempting to use it with. Once the embroidery unit was paired with the correct machine, both pairs worked.
I hope this helps.
Aug 03, 2015 | Sewing Machines
After setting up the embroidery module and preparing the thread, plate, and needle and then choosing design and hoop it wont sew. Yes, it is on. Foot pedal connected. The reverse button will not sta
Can you describe your problem a bit better.
From what you describing it sounds like the machine does start to embroider, it starts slow then it stops.
It is normal when you first start to embroider that the machine runs very slowley, does just a few stitches and stops. This is normal and all Berninas do this. The machine stops after these first few embroidery stitches so you can cut off the extra piece of thread. Cut off the extra thread then push the reversing button again and the machine should start to embroider. It will stop again if a color change is needed. This information is provided in your owners manual.
Make sure you have lowered the feed dogs for embroidery and there is no need to have the foot control attached for embroidery though it won't affect anything if it is attached to the machine...
Sep 16, 2014 | Bernina Artista 180
How to transfer embroidery patterns to Brother sewing/embroidery machine
Machine designs first designator is the file name. Your machine shows the file number for the design you want. You do still need to "select" that design number shown to actually begin teh file transfer from a thumb drive or cable direct from your computer if your machine has that feature.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Aug 22, 2014 | Brother SE400 Computerized Embroidery and...
Do feed dogs drop automatically on SE-400 when embroidery unit is attached?
Yes they should unless the tab on the middle of the embroidery unit is broken.
Jul 31, 2014 | Brother SE-400 Sewing & Embroidery Machine
How do I attach my embroidery foot to my Janome 8080?
if its like the 8000 and 9000, you unscrew the metal part that clips onto the foot, and attach the plastic embroidery foot ( P?) instead. It does not just clip on like other feet. the screw holds the embridery foot in place
Sep 17, 2010 | Janome 8080 Computerized Sewing Machine
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
Jul 11, 2009 | Baby Lock Ellure
Trouble with Viking 955E Embroidery Unit and Control Panel
Welcome to FixYa. Hi - Viking has online tutorials for several of the 955E features, including embroidery.
Here is a link to the 955E tutorials:
http://www.husqvarnaviking.com/us/6616_393.htm
Some general hints and tips:
  • Always turn your machine off when you attach or remove your embroidery arm or when you  insert or remove an embroidery design card.
  • When you insert your embroidery arm, insert an embroidery design card. When you turn your machine back on, you should see a message on the info screen that says something like "embroidery arm will move". Press OK, and the embroidery arm will calibrate.
  • After the embroidery arm has calibrated, place your hoop on the embroidery arm.
  • Look at each end of your embroidery arm - you will find a connector that must slip into a corresponding connector on the embroidery machine. This connector slides into a corresponding connector on the machine. The connector on the machine has a cover that slides open and closed. If it is closed, it you might not spot it right away. You must open this slot when you attach the embroidery arm - slide the embroidery arm straight back (not at an angle), so the embroidery arm connects to the machine securely. Although you might need to nudge the embroidery arm in place, do not force it!
The Viking site also has projects for the 955E that will help you learn to use some of the features - you can probably sew most or all of the free projects on the site, but projects for the 955E incorporate features on your machine that might be available on others. And look for the free designs!
Hope this helps get you started.  If you and other readers have a minute to rate this information (good or bad, or indifferent), your rating will help me determine if I understood your question and if my answer is helpful.
A few more recommendations...You can order a manual for your machine from any Viking dealer and probably online, and I recommend that you do. Your machine has some very cool sewing and embroidery features. I sold Vikings, so I can answer specific questions about many individual features, but Viking manuals are not expensive and can help you save time and avoid irritating problems.
If you have more questions, please comment and I will do my best to help you further. I am pleased to answer general questions about embroidery, if you want hints and tips or run into problems.
Cheers, Ginny
Jan 16, 2009 | Husqvarna Designer I
Embroidery stick
Four questions:
What model Husqvarna sewing machine are you using?
Are you using a Husqvarna formatted USB stick?
Is the embroidery unit attached when you put in the stick?
Is your machine using the latest version of its software?
I might be able to give some more specific help once I know the answers to the above.
Pamsquilt
Oct 06, 2008 | Husqvarna Viking 1
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
