Question about Juicers
I bought a Hyundai Hdt-H3 Omega phone on bidorbuy and it doesn't aant to make and receive calls.
My omega 1000 juicer won't turn on - I just bought it today.
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
Apr 23, 2011 | Omega 1000 Juice Extractor
Hello, I just received my omega 8006 and it wont turn on
This juicer has a 15 year warranty which you can contact the manufacturer or retailer you bought it from depending on their return policies and exchange it.
http://www.omegajuicers.com/juicers/masticating-juicers.html
Mar 16, 2011 | Omega Juicers 8006
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
Need place in 60439 zipcode to get omega juicer repaired
What's wrong, you might be able to handle it yourself.
You can also call Omega for help. 1 800 633 3461.
Sep 30, 2010 | Omega 1000 Juice Extractor
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
the bottom to separate the base for better access
and view of the situation.
May 20, 2010 | Omega 1000 Juice Extractor
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
May 08, 2010 | Omega 1000 Juice Extractor
How do I replace the latch arm?
I WOULD CALL OMEGA AT 717 561 1105. I REPLACED ONE
ON AN OMEGA 1000 BY REMOVING BOTTOM OF JUICER
TO VIEW LATCH ARM WHERE IT ATTACHES FROM INSIDE
THE HOUSING. YOU CAN FIGURE IT OUT. IT HAS TO BE
PRIED A LITTLE AND SLIPPED UP AND OUT.
Oct 19, 2008 | Omega 4000 Juicer
How to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Dec 11, 2007 | Omega 1000 Juice Extractor
Juicers Logo
74 people viewed this question
Top Juicers Experts
David Payne
David Payne
Tom Chichester
Are you a Juicer Expert? Answer questions, earn points and help others
