Question about Intel Computers & Internet
Turn off power and reinstall the jumper in normal mode position DH61WW mother board, directly it opens cmos setup page, give save & exit it appers (turn off power and reinstall the jumper in norm
See this video i will explain in that: http://m.youtube.com/watch?v=8wHPQvEsPTU#. Plz contact me on facebook:www.facebook.com/NofearShashank
    Problem Solver:
  • 19 Answers
Seems like your CMOS battery is dead try replacing and setting bios to default settings after it
Posted on Nov 26, 2014
2 Suggested Answers
  • 177 Answers
SOURCE: no boot or beeps
My dad had the same problem but it was The Power Circuit needed replacing as the power board had burnt out.
Posted on Dec 29, 2008
Though i hve put jumper to normal posirion it shows Trun off & reinstall the jumper to normal position
I can't read those words that you flash around or see what you are trying to show me. Put it on the wrong side nothing will happen but it will clear your BIOS SETTINGS TO DEFAULT. PUT THE JUMPER BACK ON , START UP AND THEN GO INTO THE BIOS IMMEDIATLYAND CHECK YOUR SETTINGS ARE CORRECT.
Now reboot and you should go straight intto your OS if not corrupt.
Good luck and if it don't work be a little more clear on your fault.
Nov 09, 2014 | Intel Computers & Internet
How do I reset it? Joekall@optonline.net
Turn the computer off.
Turn the computer on.
When it shows "press <BLAH> to enter BIOS SETUP mode",
press the <BLAH> key.
Select 'Load BIOS defaults'.
Select 'Save & Exit'.
If that resets it, stop here.
Disconnect the AC power.
Open the side-panel on the desktop case, and look for the 'RESET CMOS' label,
close to three gold pins that are in a row. A jumper will be connected to pins #1 and #2.
Move the jumper to connect pins #2 and #3. Count to 30.
Move the jumper back to re-connect pins #1 and #2.
Connect the AC power.
Jan 05, 2011 | Computers & Internet
When i start my computer boot screen appears every time.
may be you cmos battery is weak just remove the battery and install new battery and also make sure jumper position is proper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Intel D945GCCR Motherboard
How to install the jumper in normal mode?
If i am correct, the computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position and It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try.
The jumper should look something like this: http://tinyurl.com/l8hvqr
Jun 09, 2009 | Intel DG31PR Motherboard
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Feb 11, 2009 | Intel D945GCCR Motherboard
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Nov 20, 2008 | Intel DG31PR Motherboard
Computers & Internet Logo
80 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
