Question about Philips Televison & Video
Why doesn't my HD TV have a 16:9 aspect ratio option?
It is a like 7 old and used to be able to be in 16:9 aspect but a little bit ago it stopped being able to
  • 4 Answers
It will be depending on what is connected. Do you use scart or HDMI or the antenna from the TV itself?
Via scart or HDMI there are signals which can force the television in specific television format.
Posted on Nov 18, 2014
SOURCE: 32LG30 LCD TV screen aspect 4:3
I went into options or menu on LG remote and checked 480i and it worked.
Posted on Jan 12, 2009
ward_knutson
  • 64 Answers
SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
You cant change the aspect ratio. Polaroid built this unit with a non-standard format. Here is what I found:
Don't be thrown off by other wide-screen aspect ratios. When shopping for wide-screen displays--especially flat-panel LCDs--you may see aspect ratios such as 15:9 or 16:10. They are, for all intents and purposes, close enough to 16:9 to be considered synonymous. Unless you're extremely sensitive to geometry, it's doubtful you'll notice the slight stretching or squashing they introduce.
Sorry!
Posted on Nov 25, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
  • 3 Answers
SOURCE: LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Posted on May 17, 2009
  • 105 Answers
SOURCE: Our TV has only 2/3rds visible. The 1/3rd is black
Y Main board has failed.
Y Main controls vertical lines in the picture. Plasma TVs have x2 of these Boards. One for left and one for right. It sound like one of these has failed. Loose connections may also result in the symptom you reported
Posted on Jul 20, 2009
Hdmi from laptop to tv small picture no sound
First the picture size is probably related to the screen resolution or aspect ratio. In Windows 7, you can adjust the resolution by right clicking on the desktop and choosing Screen Resolution. Make sure you do not exceed the limits of the video graphics output of the laptop or the refresh and resolution of the TV. (Without knowing your hardware, I can't tell you the actual settings you should use.) Usually HD TVs are either 720p or 1080i. Alternatively, check if you can change the zoom or aspect ratio (4:3, 16:9) on the TV. Those settings may fill your screen. (It could expand the image past the viewable edges of the TV or distort your image though.)
For the audio, you should check the Sound outputs. Again in Windows 7, click Start > Control Panel > Hardware and Sound > Manage Audio Devices. Under Playback, see if you have an option for HDMI sound. If you don't have this option, you will need to connect an audio cable between your computer and TV. (If the TV has a VGA input with a PC audio jack, use a 3.5 mm audio patch cable. Otherwise, you'll need a 3.5 mm to RCA audio adapter or cable.) Make sure that the audio isn't muted.
If you have a different OS, the specific commands will be slightly different but similar in Windows.
I hope this helps.
Oct 18, 2011 | Televison & Video
Cannot get full screen picture. seems like I still have a 36 inch tv. It is a 42 inch LG plasma hdtv
It seems like you're expecting a 16:9 ratio picture. If you're sending a 4:3 ratio signal to the TV, you'll get a 4:3 ratio picture. An option would be to use the remote and set the TV to a 16:9 ratio picture, but that'll stretch the picture and make everything look fat. Another option would be to use the remote and zoom in, but that'll chop off the top/bottom of the picture a bit. Either case would be annoying. Some make matters even more annoying, some programs are broadcasted in a 16:9 ratio signal, but the actual picture is really 4:3 ratio. So...... as long as the pictures don't look skinny, fat, or chopped off, just accept it. If you're really that picky, just watch new Blu Ray movies only.
Jul 22, 2011 | LG Televison & Video
I bought a out of the box 47 inch Visio LCD E470VLE. Comcast is the cable provider. The entire picture doesn't fit in the screen. I have tried everything in the menu. We miss the sports scores on the...
This is a problem with aspect ratio. You need to find the correct combination of settings between your Comcast menu settings and the television menu settings. I personally have Directv, but there should be something of the same effect in the Comcast menus. On the remote control that came with your cable box, press the menu button and navigate to the settings, and from there display or picture. There should be a setting relating to the aspect ratio, and the same applies for the built-in TV menus using your Visio remote. A typical widescreen LCD has a ratio of 16:9 or 16:10. I hope this helps in some way!
Jul 19, 2011 | Televison & Video
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
HD programs work fine, however, the standard pictures are distorted. I had this once before and someone fixed it but not sure how.
You probably need to to turn your aspect ration on the TV down. Newer HD screens use a 16:9 aspect ratio for HD content which is a wide screen format. Standard definition TVs and programs use a 4:3 aspect ratio. Most flat screen TVs have an option to display in 4:3. This option is most often found in Menu/Setting>Video Options>Aspect Ratio. For standard definition programming you want 4:3, for HD you want 16:9.
May 05, 2011 | Televison & Video
I re-scanned my channels this weekend because I lost HD on 2 of my local channels. Now I have HD back, but I have 2 black lines on each side the picture on all of the HD channels. How do I get rid of the...
A broadcaster will transmit an HD channel in 1 format. This may be 720p or 1080i, both of which are HDTV formats. HDTV formats have an aspect ratio of 16:9. SDTV or standard definition broadcast have an aspect ratio of 4:3. Because not all content is record in an HD format (ex: Judy Judy), the broadcast is faced with 2 options. #1, stretch the 4:3 picture do that it fills the 16:9 canvas. #2, simple place black side bars on each side of the 4:3 image. What you are seeing is the latter of the 2 options. You will notice a change during the evening programming. The bars are only there when the content is not HD. You can use the WIDE feature of your TV to stretch the picture so that it fills the screen, just like broadcaster option #1 above.
Mar 15, 2010 | Vizio VW37L 37 in. LCD HDTV
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The RDR-VX535 does not transfer the 1:33 aspect ratio from VHS to
Did you try the unscaled option, that sould fix the issue.
Apr 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Televison & Video Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
