Question about Casio FX570MS Scientific Calculator
how to change an answer in terms of square root?
SOURCE: square root of 0.5
Hello
If you want a number in decimal form all you have to do is press [S<-->D].
Hope it helps
Posted on Sep 06, 2009
SOURCE: It wont give the answer to the square root of 76
Maybe your syntax is incorrect. But more likely, it gives the right answer but you do not recognize.
Look on the narrow indicator band on top of the screen. If there is a Math indicator you are in MthIO (textbook display). In this mode results are in the form of radicals
SQRT(76) =2*SQRT(19) Here SQRT represents the radical (square root symbol).
If there is no Math indicator, your calculator is in LineIO and all results are in decimal form so that SQRT(76) =8.717797887
To set MthIO press [SHIFT][MODE][1:MthIO]
To set LineIO press [SHIFT][MODE][2:LineIO]
To toggle between radicals/fractions to decimal press [S<=>D] key above the [DEL] key.
Posted on Jan 20, 2010
SOURCE: wene i type in the square root of 48 the answer is
If the result is already calculated and displayed, press the
[S<=>D] key It will convert a fraction or radical to decimal. This
is always possible. If the result is decimal it may be converted to a
fraction or a radical (Not always possible).
If the expression to
be evaluated is still in the command line and you have not pressed the
[=] key, you can force the result to be displayed in decimal format by
pressing [SHIFT][=] instead of just [=].
More permanently. If you
do not care for fractions and radicals, set the Input/Outpout mode to LineIO.
To do do press [SHIFT][MODE] to access the (SETUP) screen and select
[2:LineIO]
Posted on May 25, 2010
SOURCE: i dont know how to
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Posted on Jan 14, 2012
Dec 07, 2016 | Office Equipment & Supplies
Aug 12, 2014 | Texas Instruments TI-15 Calculator
Mar 03, 2014 | Casio FX-115ES Scientific Calculator
Feb 02, 2014 | Texas Instruments TI-84 Plus Calculator
Sep 16, 2011 | Casio FX9750GII Graphic Calculator
Sep 07, 2011 | Casio fx-300ES Calculator
Aug 07, 2011 | TOPICS Entertainment Snap! Geometry...
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
Feb 18, 2010 | Texas Instruments TI-30XA Calculator
Feb 04, 2014 | Casio FX570MS Scientific Calculator
63 people viewed this question
