Question about Brother LS-2125 Mechanical Sewing Machine
Replace fuse noise then sudden power loss and light went out. Is it a blown fuse and how can I replace it.
  • Leanne Mackenzie
    Leanne Mackenzie Nov 09, 2014
    It didn't sound like a motor noise. It was a little " pht " noise and power and lights went out suddenly. No noises prior to this. That's why I thought it may be a fuse. If it is, is there a special fuse I should buy?
  •  Mikey
    Mikey Nov 09, 2014
    The fuse is a normal house fuse within the plug! Pull the plug out from the mains and on the underside might be a flap holding the fuse in that you can prize open using a fingernail or small screwdrivers! If no flap then remove 2 screws on the underside of the plug and the fuse will be inside the plug, race with the same amp rated fuse, probably 5amp!
  • 5,670 Answers
Because of the noise it sounds like a motor problem! The fuse is in the mains plug and is easily replaced!
Posted on Nov 09, 2014
What does stepping motor error mean?
take to service center. where are fuses is this a brother/
Nov 11, 2014 | Sewing Machines
9960 quantum stylist
the step down is automatic,you need to contact singer for service,there is a fuse in the plug also,www.singerco.com/uploads/download/1242_9960_esf.pdf
Apr 27, 2017 | Singer Sewing Machines
I'm guessing that you may have had a power surge that caused an overload, OR the machine went in to some sort of protective mode. With the newer machines, if you bend a needle, for example, the machine will lock up until you can fix that problem.
I'm also guessing that your repair person doesn't really know your machine very well. Usually there are indications that the motherboard is going. I've blown them and it has never happened all at once. You might want to get a second opinion from someone well known in the repair business. Good luck!!!
Apr 10, 2014 | Singer Sewing Machines
Janome memory craft 9000 fuse blowing
You probably do not have the correct fuse, it is a slow blow type and difficult to find. Purchase one from a dealer that sells Janome.
Dec 28, 2017 | Sewing Machines
My Singer Quantum 9960 machine was accidentally plugged into a 220volt supply as I am currently in a country that uses 220volt. The LCD screen lights up for less than one sec and then went off. I...
this happen to me exactly - i checked and the fuse is blown, which is a good thing because it will hopefully have saved the rest of the machine from being toasted. I will find out soon once i get a new fuse.
Apr 22, 2011 | Singer Sewing Machines
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i...
There is a fuse in the the base plate
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Aug 01, 2010 | PfaFF Tiptronic 2030
Pfaff Tiptronic 6270 just stopped working!
There is a fuse in the the base plate that has blown. It is soldered in and is special fuse you won't find at Radio Shack. Unfortunatly it needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff).
Sorry for the bad news and best of luck.
Jan 15, 2009 | PfaFF Tiptronic 2040
Janome 9000
On the bottom of the machine is the base plate, remove it. You will see a black box (the transformer) that needs to be dismantled. Once inside you will see 2 fuses, one will be blown.
Replace the blown fuse, do not remove both fuses at the same time and get them confused.I bought replacements at Radio Shack. Good Luck
Dec 31, 2007 | Janome Memory Craft 9000 Computerized...
Power
There is no fuse in the BLE8 Evolve. If the bulb burns out it may appear to have no power.
When you use the foot control does it move or make any noise? If it moves or makes noise make sure it is not in the locked threading position. Change the bulb.
Nov 22, 2007 | Baby Lock Eclipse Serger
Brother LS-2125 Mechanical Sewing Machine Logo
185 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
