I have a JVC KD-R431. I have exceeded the folder limitation of 255. Is there some firmware that can improve the use interface to recognise all or more folders?
USB containing MP3's is inserted but deck says "unsupported" and will not display songs. I transferred songs on an IMac to the USB if that matters.
Using an unsupported USB device can result in abnormal playback or display of the audio file. Even if you use the USB device conforming to the above specs, audio files cannot be played normally depending on the type or condition of the USB device.
Feb 21, 2016 | Alpine CDE-143BT Advanced Bluetooth CD...
Why is the volume on my JVC KD-SR80BT limited to 30?
The number on the panel of your car stereo is not a measure of actual volume. It is just a comparative scale, with 0 being the minimum and 30 being the maximum. The volume as measured in decibels is dependent on the power level of the amplifier and impedance of the speakers. The internal amplifier puts out 22 watts per channel (50 watts peak) into 4 channels, and there are output jacks for an external amplifier(s). Product specs in link.
JVC KD R850BT
Mar 01, 2015 | JVC Car Audio & Video
Some albums in USB stick are not recognized by JVC X40 USB reader
hi mark, before going further try this out.......use a smaller usb stick like a 4gb or 8gb with some music mp3 data arranged in folders like the way you have, and check out the response/performance. from my experience many car units cannot run/decode info from large capacity usb drives. if this also does not work then check out your nearest jvc service centre for advice. cheers.
Feb 24, 2013 | JVC Kd-x40 1 Din Digital In-dash Car...
I have a jvc kd-r431 am having to keep setting my settings everytime I turn the car on, it's not holding its mem
Its the wiring of the JVC. I've had the same problem but now know the solution. Take out the stereo and disconnect the wiring from the car and the stereo. The connector has two wires Red and Yellow. Pull them apart and connect both as Red with Yellow (or other way round). Once your done all you have to do is reconnect everything and there you have it. Hope this helps
Jul 26, 2012 | Car Audio & Video
Hello, I have a JVC KD-S33, and I just hooked up the interface on the back of my stereo. I can't figure out how to set the stereo to play my ipod touch. The manual seems like chineese to me. The manual...
You can download the detailed user manual for your JVC KD-S33 in English from the following link.Please refer pages 18 and 19 of the pdf document for doubts regarding connecting the iPod touch with the stereo.( http://dl.owneriq.net/8/8abcc36e-cf2e-4b5a-a002-e343f1ffb6bc.pdf ).Please don't forget to rate me if you are satisfied with my solution.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 17, 2011 | JVC KD-G200 CD Player
I have a JVC KD-AHD79 stereo. I tried plugging my Samsung Fascinate phone into the USB port to use the music on the memory card but it either says "cannot play" or gets stuck on...
This unit is able to take I Pod and I Phone. If unable to connect your particular phone/device via bluetooth please note the following?
• Make sure all important data has been backed up. • You cannot connect a computer or portable HDD to the USB input terminal of the unit. • Avoid using the USB device if it might hinder your safety driving. • Electrostatic shock at connecting a USB device may cause abnormal playback of the device. In this case, disconnect the USB device then reset this unit and the USB device. • Do not leave a USB device in the car, expose to direct sunlight, or high temperature to avoid deformation or cause damages to the device. • This unit may not play back files in a USB device properly when using a USB extension cord. • USB devices equipped with special functions such as data security functions cannot be used with the unit. • When connecting a USB cable, use the USB 2.0 cable. • Do not use a USB device with 2 or more partitions. • Depending on the shape of the USB devices and connection ports, some USB devices may not be attached properly or the connection might be loose. • This unit cannot recognize a USB device whose rating is other than 5 V and exceeds 500 mA. • Do not pull out and attach the USB device repeatedly while "READING" is shown on the display. • This unit may not recognize a memory card inserted into the USB card reader. • Connect only one USB device to the unit at a time. Do not use a USB hub. • Operation and power supply may not work as intended for some USB devices. • The maximum number of characters for: - Folder names : 63 characters - File names : 63 characters - MP3 Tag : 60 characters - WMA Tag : 60 characters • This unit can recognize a total of 65 025 files, 255 folders (255 files per folder including folder without unsupported files), and of 8 hierarchies.
Good luck with it.
Mar 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Cant get my iphone / ipod to play with the jvc kd-avx11
According to Crutchfield.com, which does hands-on research, "The KS-PD100 is not compatible with the iPod touch (1st, 2nd generation) or iPhone/iPhone 3G. This iPod interface will also not charge the iPod nano (4th generation)."
I'm currently a victim to this JVC abandonment too.
I'm looking for a 3rd party adapter that may solve this... Jvc better get on the ball because Ipods are moving forward with newer models...
I'll get back to you if I find a compatible adapter..
K
Jun 09, 2009 | JVC KD-AVX11 Car DVD Player
Help
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
41 people viewed this question
 Grubhead
Grubhead
