Question about Intel Computers & Internet
Turn off power and reinstall the jumper in normal mode position what can be done?
Hi plz see of my video which i hve posted i cant explain thats y
    Novelist:
    Scholar:
  • 194 Answers
Your video is shakey and does NOT show where you placed the jumper. The only thing i can think of is that it's the CMOS reset jumper. Look at your motherboard user manual for a drawing/diagram and locate the CMOS jumper. Usually there are 3 pins. Pins 1 and 2 are where you want to place the little plastic thing you were holding in the video.
Posted on Dec 16, 2014
Though i hve put jumper to normal posirion it shows Trun off & reinstall the jumper to normal position
I can't read those words that you flash around or see what you are trying to show me. Put it on the wrong side nothing will happen but it will clear your BIOS SETTINGS TO DEFAULT. PUT THE JUMPER BACK ON , START UP AND THEN GO INTO THE BIOS IMMEDIATLYAND CHECK YOUR SETTINGS ARE CORRECT.
Now reboot and you should go straight intto your OS if not corrupt.
Good luck and if it don't work be a little more clear on your fault.
Nov 09, 2014 | Intel Computers & Internet
Turn off power and reinstall the jumper in normal mode position) what can be done?
turn off the power
unplug the Power cable from CPU
see the manual of the motherboard or search out "CMOS Jumper clips" these are 3 pins in which 2 are covered with a small clip (called JUMPER), (most probably this is placed near battery) remove them and change the position, eg if the same are in position of 2+3 then move them to 1+2 or vice versa.
Now power on.
vote me if found helpful.
Aug 05, 2011 | Intel D945GCCR Motherboard
i get jumper the error massage is " Turn off power and reinstall the jumper in normal mode position
Sep 10, 2009 | Intel D945GCCR Motherboard
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Feb 11, 2009 | Intel D945GCCR Motherboard
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Nov 20, 2008 | Intel DG31PR Motherboard
Computers & Internet Logo
98 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
