Question about Audiophase SkyBox CD Boombox
Audiophase Model N5500
Works with electric plug, but not with fresh batteries. How do I make
the batteries work?
On the back of the unit there is a small off on switch which just says charge? Not sure where that charge is coming from. Unit is not working at present.Item is Audiophase 315 cd player
The charge switch is used when your Audiophase CD player is using rechargeable batteries. The external plug-in power supply is used for charging.
Feb 06, 2017 | The Audio Players & Recorders
What wires on the drivers side power window block plug will makethe window go up
You have to switch polarity of the two wires going to the motor. That is what the window switch does to change direction.It's a whole lot easier to get a new window switch from a junk yard or at an auto parts store.
Jan 01, 2016 | Cars & Trucks
Rca 7" tablet wont start agan
Unplug the battery.
Unplug electricity.
Press and hold down the start-button for 30 seconds +.
Plug in electricity, NOT the battery.
Try to start.
If this works, let it boot totaly then turn it off.
Plug in battery and electricity.
Hope it works, good luck
Dec 29, 2013 | Computers & Internet
My Thomas 6v Ride -On Train works, but VERY slow. It sounds like its really struggling to go. I have TWO fully charged batteries so I know its not the battery. Everything else on it works great...
It sounds to me like your battery needs to be replaced. The batteries lose their ability to hold a full charge after some time (especially if they've sat for a long while without a charge). You can get the battery tested at a trusted shop, but it might be more econimical to just replace the batteries with fresh batteries and see if that solves the problem. New batteries will charge much better and hold the charge much longer.
Sep 23, 2013 | Peg Perego Gaucho Superpower
What grounds wires makethe chevy caprice classic 91 run
ground to battery,starter ground,and ground underneath car is a flat woven ground wire from body to engine
Jan 15, 2013 | Cars & Trucks
I have a rapport 337. It won't work with the batteries it tries but screen goes blank. It works fine if it is plugged into the wall. Any help with this would be appreciated. than you
Production of this tester has been discontinued by the manufacturer.
I read a review of this tester, and that person cautioned on the tool's short battery life. He said you need to use high capacity NiMH batteries. He says he's lucky to get an hour of life out of a freshly charged set. Furthermore, the tool does not like to even power up if there is less than a 3/4 charge left of the batteries. He recommended removing the batteries when done using the tool and placing them in a smart charger until needed again. ALL NiMH batteries self discharge even when not in use. You should always have and install freshly charged batteries when you need to use the tool.
If the batteries are old (had many recharge cycles) or were not charged in a smart charger the useful life may have become significantly reduced and in need of replacement.
Mar 05, 2012 | RTO Wonwoo Rapport337 Professional CCTV...
My 2000 yamaha r1 has no battery why wont it start with a car batery everything else works fine
It is OK to use a car battery to run the cycle if it is 12 volt to 12 volt. If the battery is still in an automobile, DO NOT HAVE THE CAR RUNNING. This can damage your motorcycles electric system. Also be careful not to crank your starter motor to long . You will over heat it and burn it out. If the cycle will not start you may have a plugged fuel system or WET fouled spark plugs. Make sure your fuel system is clean, you have fresh fuel , and if the plugs are wet try a new set of plugs. If you tried to jump start the bike from a car battery in a car that was running, you may have much more serious issues to deal with ( CDI , pulse pick ups, coils, etc.)
Feb 18, 2011 | 2000 Yamaha YZF-R1
I have a 6 vvolt DC power supply that I was using use with the audio phase GD player. When I plug it into the player, The playere will not turn on. I unplug the power supply from the player and the...
It may have a little switch so you can choose to either use it with a battery or with the power supply. If not try taking out the battery and see if it works. If it does not work with the battery taken of then it is the power supply. You can further check if the power supply is putting out voltage with a multimeter if you have one. Note that it might read a a few volts higher than 6 volts which is normal. If it reads less than six volts then it is no good.
Sep 14, 2010 | Audiophase CD315 Personal CD Player
Bike wont start
I have had batterys that will put out enough amps to spin the starter, but will do this with a voltage to low for the electronic ignition to fire the spark plugs. Can you push start the bike? If he bike has been sitting for a while it helps to drain the carb bowls to get some fresh fuel from the tank into them. Sorry this is a couple of quick fix options, you may need to post the question again if this doesnt help
May 07, 2010 | 2004 kawasaki ZX-6R
T.V. Has nopower
Try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't come on, and there is no indication of electricity getting through, the problem will be with the TV's power supply or it's cable.
Mar 26, 2009 | Panasonic CT-36SX31 36" TV
Audiophase SkyBox CD Boombox Logo
110 people viewed this question
Top Audiophase Audio Players & Recorders Experts
Jaime Hernandez
Are you an Audiophase Audio Player and Recorder Expert? Answer questions, earn points and help others
