Question about Sewing Machines
My machine beeps while I'm sewing and none of the buttons will work! Any idea what's wrong?
It happened before. When I took it to a dealer they couldn't find anything wrong! That was 6 months ago it's doing it again,
  • Kim Hamilton
    Kim Hamilton Nov 10, 2014
    It's a Janome Memory Craft 6600
  • 36 Answers
Check you pressed foot lever, my grands set mine off a lot by forgetting to get it fully down.
Posted on Nov 09, 2014
Testimonial: "Thanks but it's not the pressure foot."
  • 8 Answers
SOURCE: LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
SOURCE: Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
SOURCE: F2 error on brother sewing machine..what does it
On mine this means the button for reverse is stuck. Just wiggle the button a bit and it will pop out again. It can get pushed in at a slight angle and catch a bit, but nothing is broken... I don't know if this is the only thing F2 means, but it is one thing!
Posted on Mar 26, 2010
SOURCE: Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Posted on Aug 14, 2011
Babylon Intel a stitch 6500 All Push PUSH BUTTON BEEPS DOES Not sew
The beep is a message to the user that the machine is not ready to sew. Something on your machine has not been done or a problem exists preventing it from operating. Try calling your local dealer. They may be able to give you some ideas what to check, or take it for service.
Oct 28, 2016 | Sewing Machines
My Viking Rose will start, sew 3 stitches, then stop and raise the pressor foot and beep over and over. Do you have any idea what is wrong?
here's some suggestions
need new needle
needs to be rethreaded top & bobbin
needs to be cleaned under the needle plate & in the bobbin area
for lint
the wrong foot is being used
if none of these suggestion help then the machine may have to
be checked
Sep 09, 2012 | Husqvarna Rose
Babylock Esante ESE-2 error beeps when performing embroidery arm test?
Something is wrong with the sensors. Take it in for a repair.
Aug 23, 2012 | Baby Lock Esante
Serger won't sew
is there any smell to the machine?
it's possible that sewing the thick fabric could have caused the machine
to jump time
it would be a good idea to have it serviced at a sewing machine shop
Apr 28, 2012 | Elna Sewing Machines
I started at the edge of fabric but ended off the fabric.Now E-1.
Check the bobbin area to be sure there aren't any thread tangles that may be causing the jam.
Take it back to the dealer and show them what is happening.
It sounds like the timing might need adjusting.
Apr 20, 2010 | Janome Memory Craft 4800QC
Machine will not start
There could be something wrong with you cable might try to change it
Mar 08, 2009 | Singer CE-200 Quantum Futura Computerized...
I try to make a button hole with the 9940 Singer machine and I continue to come up with the machine doing nothing. I follow the directions in the manual, the presser foot I've changed to the correct one...
To the left of the foot there is a silver button hole lever pull this down fully.
Make a note in your handbook for next time as recently this happen to me and it took me hours to work it out.
Hope this is your answer.
Feb 24, 2009 | Singer Quantum 9940 Computerized Sewing...
Singer 7436 beeps - not working
Check to be sure the buttonhole lever is in the up position and the presser foot is down. Check feed dogs to be sure they are in the up position.
sewman7
May 26, 2008 | Singer 7436 - INGENUITY
Beep sound on Kenmore 19233 sewing machine
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develop in the threading process and you are able to sew a few more stitches before the beeping starts again.If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. If it continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house.
Nov 05, 2007 | Kenmore 19233 Computerized Sewing Machine
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
