Question about Bosch 1999 BMW 528i Cabin Air Filter
1999 528i bmw ash tray door wont stay closed why?
  • Bosch Master
  • 5,533 Answers
Clip broken!
Posted on Nov 09, 2014
How to replace 95' chevy sub ashtray spring
First thing we need to do before anything is to remove the little feet that the ash tray sits on when it is open, and bend their tabs out of the way so we can open the ash tray to its fullest open position.
To do this, you'll need to play contorsionist a bit, and pull out the little rubber pads from behind the ash tray, then carefully bend the tabs back into the side wall of the ash tray assembly. You can refer to my pic below to see which tab I mean -- And you can also see the remains of the rubber foot in the background .
Once both of these tabs have been bent out of the way, you can then take the ash tray door, and pull it down towards the floor as much as you can.
Doing this will expose a small pin head sized hole in the side of the ash tray, and also a rounded triangle in the sides of the assembly housing, with a small notch at the top. The springs sit inside of these four holes / notches.
Ok, so now that you've got your springs ready to go, its time to install them. You want to take the end of the spring that has a little bit of a bend to it, and slide it into the hole. This will keep the spring from falling out in a few seconds. Once you've got the springs into the side of the ash tray, you'll want to take a skinny screwdriver, and use it to push the spring up and behind the ash tray where you can grab it with your finger.
Then both slightly close, and move the spring into it's proper slot at the top of the triangle. Repeat for the other side, and close the ash tray. It should hold itself shut, if not, make sure that you've got the coils of the springs oriented towards the firewall.
After you've got that finished, then bend the little tabs for the pads back to where they were, and re-install the little pads. You're good to go!
We Are Here To Help !!!
__________________
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Sep 02, 2014 | 1995-1997 Chevy Suburban Ignition Starter...
Saeco Giro flashing
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed, the service door is open.
on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Coffee Makers & Espresso Machines
Replace old ash trays with new ones on rear door panels
Any salvage yard should have a few cars to get them out of, they usually are like new.
Jun 02, 2012 | 1999 Lincoln Town Car
Ashtray in my 2005 Kia Amanti Stays open
It sounds like the spring mechanism on the tray is either bent or broken. You can try removing the tray and bending the spring steel to increase the friction or you may have to purchase new or used ash trays.
Nov 23, 2011 | 2005 Kia Amanti
Ashtray won't stay closed. how to remove ashtray assembly
The trim panel around the radio / HVAC controls needs to be removed to get to the screws.
To remove the trim panel, open the ash tray and pull on each lower corner. There are 3 spring clips on each side holding the trim in place. The 1st time you do this, they are a bit hard to pull out.
The black circles in this picture are where the spring clips are
If you can just hang the panel to the side or have someone hold it, you can get to the 2 screws on the top of the ashtray assembly ( there are just above the black sides of the ash tray in the picture above ). The ash tray is pulled out and down, it is farther in the dash than it looks. Once out, you can take a look at the springs on the side / back that hold it in, to see if they broke off or fell off.
Apr 20, 2011 | 2004 Ford F150
The ashtray door/cover will not stay closed in the dash 06 Zephyr
I found that if you take the ash tray out there is a little hole. shine a light in it and you should be able to see a slide mechanism on it push it over to the side and the door will lock,might want to put a little lube in it and that worked for my 06 zephyr
Apr 16, 2010 | 2006 Lincoln Zephyr
HP 2200D Amber light keeps flashing! ..and nothing else
Following are the reasons and its solution for amber light keeps flashing:
1. Toner have been empty.
Sol : Refill you toner.
2. Printer's paper tray do not close properly or paper in not in the tray.
Sol : Close the paper tray properly and keep some papers in the tray.
3. Any door of printer is open or not properly close.
Sol. : Check all the doors that is close properly or not.
If problem is still remaining then contact a professional to repair this printer.
Regards
Ashly
Feb 25, 2010 | HP LaserJet 2200D Printer
My xbox disc tray will not close
The tray component gears were probably stripped and the tray is now shifted vertically to high or low. Because when the tray moves back and forth the inside eye set up moves into the disc to hold it. Solution Have X-Box fix you problem for around $80 or less. Call 1-800-4MY-XBOX. They will send you a postage paid box. Also check to make sure nothing lose was in the xbox and also try to slam the door hard over and over as it try to slid in itself.
May 28, 2009 | Microsoft Xbox Console
Fuse box for volvo 740
I have a 1987 740 & the fuse box is located behind the ash tray in the center console. After removing the ash tray you can access the fuse box. Each fuse description, size, & location are listed on the back of the ash tray.
Jan 07, 2009 | 1990 Volvo 740
How do you open a convertible top on a 1988 bmw 325i?
on center of dash near storage tray there r 3 buttons. above your ash tray.
Nov 16, 2008 | 2001 BMW 325
Bosch 1999 BMW 528i Cabin Air Filter Logo
54 people viewed this question
Top Bosch Heating & Cooling Experts
 Mikey
Mikey
Steven's...
Steven's...
Stan Ford
Are you a Bosch Heating and Cooling Expert? Answer questions, earn points and help others
