Question about Pedrollo PJ3015-CF N/A 1-1/2 HP High Pressure Pump with Press Flow Sy
Why water pump fail - Pedrollo PJ3015-CF N/A 1-1/2 HP High Pressure Pump with Press Flow Sy
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
See previous answer. (more details required)
Posted on Jul 10, 2016
How can I fix my Keurig Coffee maker? It pumps water from the time it is turned on 'till it indicates add water. Any suggestions?
either the heating element has failed or a thermal overheat trip device or thermal fuse has failed
you need to use a meter and see if the heating element is getting AC power
perhaps the pump actuator usualy a relay or a triac device has failed and gone short or fused contacts ....
hard one to diag from words only
Dec 04, 2014 | Keurig Coffee Makers & Espresso Machines
My water coolant is dripping from a small hole situated near the water pump , what is the problem pls
What you are describing is the beginning of water pump failure. That little hole is called the weep hole and if coolant comes out that means the pump is failing.
Nov 26, 2014 | Cars & Trucks
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
Pressure washer failed
What are the symptoms? Water in oil requires changing seals ( probably high and low pressure) Low , fluctuating pressure is probably valves need cleaning or replacement. Low pressure could also be worn unloader. Water leaking from pump is worn high pressure seals. Many possible failures.
Saying pump has failed is like saying my car does not work.
Feb 10, 2014 | Computers & Internet
There is slack in the belt around the water pump and the thing that the water pump sits on is really loose someone told me the bands in the water pump have gone out is there any way to fix that without...
A water pump would not have bands.
If the water pump pulley is loose, the bearing may have failed. If that is the case, the water pump would need to be replaced.
If the serpentine belt is loose, the tensioner may have failed.
Sep 24, 2012 | 1998 Ford Explorer
If water pump fails, how would i know? the car is an 80td, 130k . fans never cut-in, temp gauge never gets above 60. T car also consumes coolant very slowly. I understand there are many possible causes of...
Typically, when a water pump fails, it fails because it is leaking. You will lose the coolant and your car will over heat. We must not be on the same measurement ... where I am, coolant temp of 60 is very cold. Keep an eye on it ... add water/antifreeze as necessary. Watch for leaking on the ground or on the motor.
Oct 08, 2011 | 1991 Audi 80
Leaking water pump
A lot of water pumps are designed to leak when they are about to fail or have failed. But, the water pump could be okay and just leaks past the gasket.
Either way, replace the water pump. A water pump only lasts for so long and replacing it would be the most cost effective route to take seeing you are going to have to take it off anyway to put a new gasket on it.
May 04, 2010 | 2004 Dodge Grand Caravan
97 CAVALIER (Z24) FAILED SMOG TEST
No the water pump will not affect the smog test. You probably failed the idle?
Usually with this age of vehicle you can replace the o2 (oxygen) sensor and it will pass. Cleaning the MAF if it has one cant hurt either if you do it right.
Mar 30, 2010 | 1997 Chevrolet Cavalier
Leaking antifreeze, not from radiator but on belt iI believe it the water pump
Check your bottle cap, ensure that cap is tight. If it is, replace cap. Cap is not holding pressure.
Nov 23, 2009 | 1995 Oldsmobile Cutlass Supreme
Water pump leak at weep hole
This means the inner water pump seal has failed and you will continue to loose coolant. It has probably failed because the water pump bearings are worn and now the shaft is loose. You will need to replace the water pump.
Nov 01, 2009 | 1995 Suzuki Sidekick
Pedrollo PJ3015-CF N/A 1-1/2 HP High Pressure Pump with Press Flow Sy Logo
161 people viewed this question
Top Pedrollo Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Pedrollo Garden Expert? Answer questions, earn points and help others
