Question about Garden
Why pump fail ? - Garden
    New Friend:
  • 20 Answers
When using a pressure washer, my instructions said not to let it idle for more than 5 mins because the water that cools the pump gets hot and does not circulate so it will overheat pump. Also low flow of water will cause the same thing.
Posted on Nov 10, 2014
  • Joe Bayer
    Joe Bayer Nov 10, 2014
    My instructions with my pressure washer said to not let it idle for more than 5 mins. because it has to have water circulation to cool it. If you dont pull the trigger it will get the water as hot as the pump and overheat.
Why isn't fuel pump receiving power?
Did you R/R the pump & relay for this no start condition? First ck ALL the fuses if OK you probably have an electrical short. Ck ground circuits too.
Oct 24, 2015 | Geo Tracker Cars & Trucks
It is not pumping engine oil
You need a working oil pump to pump the oil around the engine. If the oil is not being pumped through, the oil pump has failed or there is a blockage in the lubrication system.
Most likely the oil pump has failed and needs to be replaced.
Sep 28, 2015 | Cars & Trucks
Pressure washer failed
What are the symptoms? Water in oil requires changing seals ( probably high and low pressure) Low , fluctuating pressure is probably valves need cleaning or replacement. Low pressure could also be worn unloader. Water leaking from pump is worn high pressure seals. Many possible failures.
Saying pump has failed is like saying my car does not work.
Feb 10, 2014 | Computers & Internet
Signs my 95 chevy tahoe fuel pump is failing
For how long after does it make noise it's not uncommon for the pump to stay running 3-7 seconds after shut down however if it getting noisy you may need to change your fuel filter restrictions in the system will make it noisier
Aug 31, 2012 | Cars & Trucks
What's your problem?what is making the power steering pump to fail
are you using cheap box store pumps after changing a failed pump are you flushing out the system so the metal isn't floating around threw the new pump?
Apr 26, 2012 | 1988 Audi 80
Noisy fuel pump
NOISEY FUEL PUMP IS A WARNING SIGN TO BUY NEW FUEL PUMP BECAUSE THE OLD FUEL PUMP MOTOR BEARING FAILING.THE FUEL PUMP IS GOING TO FAIL ON A UN SET TIME.
May 17, 2011 | BMW 318 Cars & Trucks
What is causing the fuel pump to fail on my 1987 Nissan Stanza? The mechanic is about to put on the third new pump.
The possible causes are a dirty fuel filter and since the fuel pump sits in the fuel tank and is cooled by the fuel, always keeping the fuel level at low or empty which causes the fuel pump to run hot deminishing its service life.
Jun 17, 2010 | 1987 Nissan Stanza
Won't empty & will not spin
These machines won't spin untill the're empty, so your problem would probably be the drain function. It's not uncommon for the pumps in these machines to get something jammed in them or even for the pump itself to fail. The pump is accessed from underneath the cabinet...Most important to empty the machine before removing the pump!!!..Probably best to call a tech, because the pump resistance should be checked.. A failing pump can cause other components to fail as well......Not a big job for a tech. Good luck...Nomess
Jun 01, 2010 | Fisher and Paykel WL37T26DW1 Top Load...
Fuel gage low gas light is on but tank is full,
The sending unit on fuel pump module is failing. Fuel pump will fail next! Change fuel pump module will solve problem and save you from being stranded on road when fuel pump fails. Common problem on GM trucks!
Feb 23, 2010 | 2005 Chevrolet Trailblazer Ext
How long does it take to change a oil pump in a 99 dodge ram the gauge keeps going to low when I come to a stop and then when I take off it goes back up.
Before replacing the oil pump, please do a mechanical oil pressure test to verify the oil pump is failing. Get the pressure specs for your engine, to verify the pump is failing. Your switch may be failing causing this concern and not the pump. IS the oil level at the proper level? These engines have an issue with the "pan" that is bolted to the lower side of the intake manifold. If your engine is using oil, and you can't find any leaks, this gasket has failed.
Jan 19, 2010 | 1999 Dodge Ram
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
