Setting up sambulo tv
Want to set up sambulo tv
What are the 3 digit codes for Huayu HR-N99? For samsung. I lost my copy. Please help!!
Input code set method
1, turn on the TV power supply, will be the normal play of the TV set, find out from the code table to the corresponding code by the remote control of TV brand.
2, hold the "set" button on the remote control, until the work light is lit up, let go of "set" key.
3, I just find a set of three digits code. Light is put out.
4, check the validity of other buttons, the effective set, invalid, repeat steps 1-3.
Search code sets method
1, let the normal play of the TV set, will be on the TV remote control.
2, hold the "set" button on the remote control, until after the work light is lit up.
3, of the press "volume +" key.
4, when the volume of symbol to appear on the TV, press the "set" button, the light is put out.
5, check the other remote control button is valid. If the button is valid, set up successfully, if invalid need to repeat step 2-4, until find the code that suits your TV set.
http://www.huayu.cc/EN/_XinWenZhongXin_v283.aspx
Feb 22, 2017 | Televison & Video
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Jan 04, 2015 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
Error: incompatible TV settings
You need to pull out the manual. The settings are related to the INPUT to the TV. You must select the DVD-CD settings from the Menu and switch from the TV setting to DVD.
Feb 26, 2014 | Sharp Televison & Video
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
TV speakers have switched off (i dont know how) how do i switch them back on again have used remote control to access sound options and does not seem to be a feature for on of off sound adjustment
Go into ur tv menu again,go to sound option again check what on the writing highlight on the tv SOUND SETTING now is it said VARIABLE SETTING.Than it is the sound setting problems,go into that highlight word VARIABLE SETTING just press the enter button on the remote to change it back to FIX SETTING.This should and will solved ur tv sound setting problems.If the sound setting already highlight word is said FIX SETTING.Than the tv have bad incomming broadcasting input signal cable or ur tv have bad or dead speakers problems to the tv itself.Not Sound Setting problems.
Apr 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
I forgot parental control passcodep
Hello
Just reset your tv to factory settings. By doing this all the settings will be set to its orginal factory mode, and you have to reset all the settings including V-Chip settngs. To set it to factory settings do the following.
Switch off the TV wiith its front panel power ON-OFF switch and wait for about 5 minutes.
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK.
Jan 12, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
Jul 19, 2017 | Audio Players & Recorders
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
TV picture now rolls when connected to A80
It sounds like the TV setting on the camera has been changed. The symptoms you describe can happen if you set the TV setting to PAL and connect the camera to a TV set that uses the NTSC standard.
Check the setting, and ensure the proper setting is being used.
Feb 11, 2008 | Canon PowerShot A80 Digital Camera
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
