Hi a Simpson esprit 550 will not hold water... Just keeps filling and draining at the same time. Any solutions?
    Filmmaker:
    Uploaded 5 video answers.
  • 37 Answers
Is your drain hose location at the proper height?
Posted on Nov 09, 2014
Nicesuit
  • 61 Answers
SOURCE: THE TECK SAYS THAT THE SIMPSON ESPRIT WILL ONLY
you can pick up a Y adaptor from a hardware store and fit a cold feed to both, it will take a few more minutes to comlpete cycles thats all, all new machines are fitted with a cold feed only to make them more energy efficent. the tech is talking pi**
Posted on Jul 23, 2009
SOURCE: Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Posted on Jan 14, 2010
beltronic205
  • 1461 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
  • 257 Answers
SOURCE: hi, my washing machine does
Check that it is't set to drip dry or spin hold..
Posted on May 13, 2011
Hi, we have Simpson top loading washing machine model number Esprit 550, the drum is not rotating and the spinning plastic rod in the centre of the drum is not spinning/rotating either
that is a direct drive
is the agitator (plastic rod )loose or sloppy
if you look down the inside of the agitator
do you see a nut at the base holding the agitator tight
if the timer is working
and water can pump in and out
that is good
bad
if you cant hear the motor click in
it will need to have the inspection cover taken off
for service or part replacement
May 20, 2016 | Simpson Washing Machines
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
Hi my simpson esprit 550 has suddenly stopped spinning,does everything else fine,any suggestions wod b much appreciated,thanku
Has it pumped out? It wont spin if still full of water. Check for blockages etc in hoses and the pump. If its pumping out, there could be a problem with the brake release or it may be the lid switch. It wont spin if the machine thinks the lid is open. Older 550,s had a switch that was operated by a lug that stuck out of the back of the lid, newer ones have a magnetic switch under the top of the machine.
May 19, 2015 | Simpson Washing Machines
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
Hi i have a simpson esprit and I can't stop the
If the water continuously keeps filling the tub of the washer this would be due to either you have a bad pressure switch or the hose that is connected to the pressure switch that goes down the side of the unit and connects to the tub has either comes off its connection point or has sediment or debris inside the hose itself which would cause the same issue here is also a basic video of how the pressure switch test is done click this link http://www.youtube.com/watch?v=HZZ2bDMspj8 if you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to continue helping others in similar situations in the future. Thanks again for using Fixya
Rick
Jun 12, 2011 | Washing Machines
Simpson esprit 550 washing machine stops mid-cycle
Mar 31, 2010 | Washing Machines
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
185 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
