Sansui LCD TV model LCDTVS2230YV-L logic card not out ps.on&bk.on set st.by mode or no work remot&panal key?
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
Posted on Mar 06, 2016
  • 8 Answers
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
Posted on Dec 27, 2008
  • 15 Answers
SOURCE: PIP ON SANSUI LCD TV
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
Posted on Feb 23, 2009
  • 396 Answers
SOURCE: I need the codes for a UEI technologies universal
www.manualsonline.com
Posted on Nov 05, 2009
  • 208 Answers
SOURCE: 37" Sansui LCD TV, help with remote codes
Much as I hate to say this, looks like you may need to find a genuine one.
Good luck
Posted on Mar 21, 2010
  • 182 Answers
SOURCE: i mistakenly engaged the key
a new remote control is available from www.tvs-services.com
there is a reset which needs to be carried out with the remote .
but you should be able to bring out of stand by with the standby button on the tv
Posted on Aug 20, 2010
Sansui LCDTVS2230YV is st.by mode or no work remot power buttan&no work panal power batan power suply 12v&5v is ok pless help
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 09, 2014 | Televison & Video
Lcd tv
Nov 08, 2014 | Televison & Video
Sansui tv code for service menu
press menu button on remote ,then channel-, then enter 1947 code services mode will open
Sep 23, 2012 | Sansui HDLCD1908 19 in. LCD TV
Cant program rca universal remote to a sansui tv
Unless the designated codes are mentioned for Sansui TV , it might not match. If with an auto selection mode , check to scan to self detect.
If not the model is out of the frequency range available.
Sep 25, 2010 | Sansui HDLCD-2600 26 in. LCD Television
Remote sensor not working on TV. Tried the original and several other remotes and none are working. Used new batteries.
pls. check tv is in chaild Lock mode / LOCK mode.
so check tv panal key use . is working ? NO then tv is in chield lock mode. see user's menual and set chaild lock trun off.
chek with new remot cantrol if not work then problum is tv set
[1] see tv frant panel on IR [simbol] clear with cloth smuthly [dust free]
if not working Remot cantrol then problum is inside tv .pls check tv by nr. tech.
Oct 30, 2009 | Televison & Video
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
CODE RETRIVAL FOR A SANSUI TV MODEL
I lost the remote to my Sansui TV and can't remember the model number. can I get a remote to replace it?, the tv was bought in 2004
Nov 19, 2007 | RCA RCR311B Remote Control
Using a Jensen remote, can't access input mode
turn on your tv, press and hold tv button, then the on/off button, it will light up then press the power button.and it turns off....hold. After holding down both for buttons for 3 secs the light on the on/off key turns back on. Release both keys and the light should stay on. Now hit the On/off button repeatedly until the tv turns off, when it does hit the stop button to save code.
Apr 03, 2007 | Jensen 143307 Remote Control
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
