Question about Ovens
How do I locate the fuse for Smeg oven sa9066xng?
To find the fuse the light went the other night have clock but nothing else
  • 5,574 Answers
The fuse is in the mains plug......but if you have the clock it won't be the fuse! The bulb has blown......replace bulb!
Posted on Nov 09, 2014
TaPuna
  • 70 Answers
SOURCE: smeg oven model SA708X--Clock faulty
hi, if you have a faulty clock it is likely the relay in the clock is stuffed you could try to repair it but i think you are better off just buying a new clock, clocks are expensive thou, so bypassing is a good choice
Posted on Sep 09, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
kachbibi1
  • 979 Answers
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Posted on Feb 11, 2009
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 174 Answers
SOURCE: The oven tripped the main fuse switch to the house
you have to set the clock befire anything works .if you have done that its could be that the element has failed and the fault current has damaged any of the contacts in the circuit which can be themostat ,timer contact thermal cut out contacts. failure of the timer contacts would leave nothing working
Posted on Aug 04, 2010
Testimonial: "Setting the clock worked a treat thanks for the advice "
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
Blows mains fuse
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
Smeg oven UK80MFX1 troubleshooting
Nov 30, 2011 | Smeg Ovens
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
Nov 29, 2011 | Smeg Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Smeg oven not working. only clock and thermostat light working
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
