Question about Craftsman Vacuums
Craftsman 8 gal wet dry vac 113177011 runs and sounds like motor surges and backs off also smells hot
  • 3,506 Answers
Check that water cut off is not sticking on.
Posted on Nov 09, 2014
Testimonial: "Will do thank you"
Sounds like you have some sort of debris clogging the intake or it got past the intake. You will also get a burning smell if there's lots of lint etc., around any of the bearings. Take the unit apart to clean and inspect the motor and impeller.
Testimonial: "Thanks I will definitely take your advice and I appreciate your time"
SOURCE: I have a 10 Gal
Here are links where the hose can be purchased.
The parts for this Model seems to have been discontinued, but there are some that still sell the part, check the link provided to get more details of the part needed, thanks.
Link1 Link2 Link3
I hope the link help, I saw the hope on Link3 and Link2, on Link1 is where the original part can be bought but has been discontinued in the market, I put the link just for details on what the original part would look like to be able to buy one that the same from the other 2 links.
Have a nice day.
Posted on Sep 07, 2011
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
reddevil6
  • 1673 Answers
SOURCE: 177611 wet/dry vac
Either you aren't getting the top on correctly so it will latch, or there maybe a problem with the latches. You should have a one year warranty on this, take it back to Sears and have them look at it.
Posted on Jan 15, 2008
SOURCE: craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
Posted on Feb 27, 2008
SOURCE: Hi, My George Wet/Dry Vac started to make a
george pump not working
Posted on Nov 16, 2010
Where do i place the foam sleeve for 5 gal craftsman wet vac
The foam just is put over the round center beneath the top of vacumn with top off the bucket. Just slide up to top of round assembly and you good to go. If you have the paper bag filter on remove it first.
Aug 31, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
I have an old shop vac floormaster wet & dry vac, 8 gal., model 700c. I need the users manual to find out how to use it as a wet vac.
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Jul 04, 2011 | Vacuums
My rotating brushes stopped rotating and my steam vac smells hot...is it a belt?
the hot smell makes me thing the motor is stuck
do not attempt to use it unless you can rotate the motor by hand. If the motor spins freely then it could be a belt. check if the belt turns
Feb 02, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Craftsman 20 Gal Wet/Dry Vacuum model number 17762
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Feb 13, 2008 | Craftsman 17762 Wet/Dry Vacuum
177611 wet/dry vac
Nov 13, 2007 | Craftsman 17765 Canister Wet/Dry Vacuum
Vacuums Logo
125 people viewed this question
Top Craftsman Vacuums Experts
Tim Doolittle
Tim Doolittle
 steve
steve
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
