I have a tat to power supply that won't power on need help
  • 3,506 Answers
Please provide more make and model etc information
Posted on Nov 09, 2014
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Power cord for Janome MC11000 sewing machine
You need to require parts from Janome, Contact them here
Jul 18, 2008 | kawasaki PVS1080
How to put samsung s5610k tat mode
you need to connect 9v battery to cable then connect to phone then press unlock.when you use message on screen say "power on phone" then you press power button then you will enter "tat mode"
Nov 15, 2013 | Samsung Cell Phones
COMPUTER WON'T START
See if power supply fan is running. If not....the power supply is bad. Also...see if there are any lights lit on the Motherboard. If not....the power supply is bad. You can pick one up on ebay pretty reasonable. Hope this helps.
Feb 02, 2013 | Dell Inspiron Computers & Internet
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
The tv wont power on at all
Your TV Won't Turn On
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. If otherwise
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if otherwise, Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Jul 07, 2011 | HP Pavilion MD5020N 50" DLP HDTV
Dell inspiron 8100 no ac power-power only with battery
You may have to run the battery/charger utility test.Look under control panel classic view.
Jul 14, 2009 | Computers & Internet
When i turn the key it sounds like rat a tat tat but does not start.
The fast click is a classic sound of not enough power.
Either the battery is low or dying, or the starter is wearing out and trying to pull more power than the battery can supply.
Once you get it started, jump-started, or whatever, take it to your mechanic to test the battery 1st, alternator 2nd, and if necessary, starter 3rd, in order of cost.
Jun 30, 2009 | 1992 Toyota Pickup
My msi km400 8237 acpi problem
If you had APM or no power management activated, you will need to reinstall windows after turning on ACPI to load the new ACPI HAL and to detect the hardware again. Otherwise windows will be confused about the type of PC it's installed on.
Jun 24, 2008 | Intel Motherboard
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
