Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
What dose 03 mean
It stopped working would not spin
  • 3,506 Answers
Google this code
Posted on Nov 09, 2014
When washing machine do not spin.dose timer continue work or has stop?
The timer usually continues to run but the contacts to the motor get corroded so that it won't get the power necessary to spin. The power needed for the spin cycle is far greater than needed for other cycles is why the spin cycle fails first.
Very rarely will a timer motor that works for the rest of the cycle stop for just the spin, but it could happen.
Just buy a new timer assembly. Get the model number and use Google; but look at several offerings noting the part number. If you find a cheap price but a different part number, buy the one that matches the factory number as best you can.
While you are working on the machine, you probably should replace the drive belt, if it has one.
Feb 03, 2015 | Hotpoint Washing Machines
The blade brake is not working on my miter saw.
Clean your saw ! Use your air compressor with an attachment to get back in the nooks & crannies, blowing all the caked up sawdust out.
Oct 09, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
WHY SPIN DOES NOT WORK?
You have something stuck between the the outer and inter tubs
Jul 13, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
My kenmore dryer heat very good but the drum stop working it dose not spin at all
Hello
The drum not spinning is either a broken belt or a faulty drum motor.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Traction active message is coming on what dose this mean?
Your car has what is called "traction Control" when wheel slip is detected by the system it takes control of the brake system and stops the spin, some cars call this Stability Control, if the light is always on then the system has a failed part and is turned off by the control unit.
Mar 08, 2010 | 2004 Chevrolet Impala
Fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny noise...like some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
May 24, 2009 | Ariston Technologies Washing Machines
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
