Question about Car Audio & Video
If your amp isnt fused what do you do
Iv hooked my kicker 250.1 amp to my stereo and it what put out sound. what do I do to fix it
  • 3,382 Answers
Be sure it is wired correctly and that it has about 13 volts if egine is running.
Posted on Nov 27, 2014
shaggyrat
  • 1224 Answers
SOURCE: no sound
did you set your gains and base boost also when you put sterio back in dash did you put rca's on proper outputs or the rca's could have pulled out when putting back in
you have high output and low output
are your subs getting sound to them at all any current going threw speaker wires to subs
radio settings might not be set to back end for subs this is a feature on most receivers to shut off back end subs
Posted on May 09, 2008
jpenn1192
  • 58 Answers
SOURCE: amp powers on but no sound!?
CHECK ALL YOUR POWER AND GROUND CONNECTIONS, THE SMALLEST PINCH WILL MAKE IT DO THAT.
Posted on Jun 18, 2009
  • 979 Answers
SOURCE: How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Posted on Nov 23, 2009
  • 1348 Answers
SOURCE: I Hooked up a Performance Teknique 1200 watt 2
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Posted on Jan 13, 2010
  • 12 Answers
SOURCE: kicker zr600 smokin havent even bumped yet today
Hi as an ex Kicker repair engineer for the UK's main Kicker distributor I am completely familiar with this amplifier! The advice I am going to give you must be carried out by a competent engineer. Chances are that the power supply mosfets are all shorted & this is where the smoke will have emanated from, this will be obvious by the appearance of the mosfets being "charred" & possibly black "Witness" marks on the pcb. There are 6 of them, 3 either side carrying the prefixes: Q43, 44 45 & Q 47, 48 & 49. If when checked with an ohm meter they are found to be short, all will need to be replaced. The following components can be used: RFG70N06 or HUF7343G. However before this is done a couple of other checks must be carried out first. Remove all 6 offending mosfets, power the amp. up on the bench & use an oscilloscope to check the pulse width modulator waveforms coming from pins 11 & 14 of U7 (PWM i.c, SGS3525) both waveforms should be identical. If there is no output then this component will need to be replaced. Now check the following resistors with an ohm meter: R92, 93 & 94 + R99, 100 & 101, they should each read 47 ohms, any that are open circuit must be replaced. These resistors are critical as they feed the mosfets with the waveform generated by the PWM i.c to produce a working power supply, necessary to generate the correct voltage rails needed to make the amp. work. When you are satisfied all is ok then you can replace all of the mosfets as detailed earlier, before powering up again though 1 further check will be required. Using the ohm meter again check all of the output transistors for short circuits, there are 16 of them & are identified by the following prefixes: Q13 - Q16 (TIP35C), Q17 - Q20 (TIP36C) & Q33 - Q36 (TIP35C) + Q37 - Q40 (TIP36C) if any are found short circuit between any of their pins they will need replacing. This amp must be protected by 3 x 30 Amp fuses (90 Amps) & the in line fuse feeding the Amp. power cable should include the same rated fuse. If you manage to repair this ok make sure the installed cable is has a large enough cross section to supply this current, if it does not chances are this was the cause of the mosfets blowing in the first place. All the best! acbva.
Posted on Mar 04, 2010
I have a Kenwood 1800wat amp with to 10" Sony kickers, I was driving to my new town when all of a sudden the subs stopped working. I reached around and pulled 1 off 2 fuses were blown and it was a 40amp...
If the fuse should blow up; there might be a reason. Shorted component at the power amplifier circuit board of the sub-woofer amp. It will be best to contact any service technician to check the set. Never insert a fuse and switch ON the set, till the fault has been detected and rectified. It might make things worse.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 15, 2014 | Car Audio & Video
I have a kicker two ch amp and when I hook up my two 15s which ever sub I hook to the right CH flexes weird and don't sound like the one hook to the left CH
well what ampage is your amp ?? for example if its a 350 amp and you have two speakers at 200 each the sound quality will be **** in other words but if you have 1 thats 150 and 250 the less powered speaker is going to give out more sound. either that or one of the channels is broke or weak
Aug 23, 2012 | Car Audio & Video
My amp stopped working
Its a short inside the amp. Sorry to say, but you will have to have it fixed or buy a new one which sometimes cost about the same. Good Luck!
Jul 10, 2010 | Kicker 06ZX1002 Car Audio Amplifier
Speakers pop or rumble when stereo is turned on
AMP HAS PROBLEM.. SOUNDS AS THOUGH THE LINE INPUT AMPS HAVE PROBLEMS IN AMP ALSO ONE THING TO CHECK WOULD BE TO DISCONNECT SPEAKERS AND HOOK UP RCA'S.. CHECK THE SPEAKER OUT PUTS WITH A DC VOLT METER TO SEE IF YOU HAVE DC VOLTAGE ON THEM IF SO YOU HAVE SOME SHORTED OUTPUTS
Apr 24, 2010 | Kicker ZR600 Car Audio Amplifier
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
Jul 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Bass not Very deep
250 watts rms seems a little low for a 12 inch woofer, a 500 or higher will likely fix your problem. Specific model numbers and the type of enclosure you have will allow a more specific answer.
Mar 17, 2009 | Car Audio & Video
Protection light
double check the blue stereo input wire to amp is this a new amp if not speaker channels in amp might be blown
Nov 08, 2008 | Kicker KX120.2 Car Audio Amplifier
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
