The plug that fits into the cigarret lighter is broken. Where can I buy a replacement car charger?
  • 3,506 Answers
What make and model do you have?? You will likely find an answer on google if you have this information available. China usually has all of these things available.
Posted on Nov 09, 2014
2 Suggested Answers
SOURCE: we have a emerson portable
Go to radio shack
maybe there find something useful
Posted on Jul 27, 2010
Cig lighter fuse keeps blowing out
Research what else is on the circuit. In the old days when cars had more than one cigarret lighter I discovered that a penny fits in the socket perfectly and would cause a short.
Apr 06, 2014 | 2004 Chevrolet Tahoe
2005 mercedes-benz e320 . lighter outlet cigarrete is mot working and it isnot the fuse,, what should i do?
With the ignition off try prying the tabs closed on the inside of the cig lighter. Sometimes they get spread apart to far when using auxillary chargers. Make sure the ignition is off or you will short to ground and pop the fuse for sure. If that doesn't work and the fuse is good then you'll need to replace the cig lighter as a complete assembly.
Sep 27, 2012 | Mercedes-Benz E320 Cars & Trucks
Cigarrete lighter no power
check the fuse in the box usually inside the car under the dash. there should be a list on the cover showing you where the lighter fuse is. check it to see if it is blown.
Aug 26, 2012 | 2004 Honda Accord
Fuse card missing on lid of fuse box VW Beetle Turbo 2002 and need to know location of cigarette lighter to check if fuse is ok as chargers not working. Please help. Cheers
The fuse panel on 2002 VW Beetle Turbo is located behind a plastic cover on the driver's side end panel of the dashboard, door open. The fuse no.# 1 - 10A (red colour) is for cigarrete lighter. See pictures below:
Apr 03, 2011 | Volkswagen Beetle Cars & Trucks
I brought a new Garmin nuvi 1490T recently from Staple. The only problem is the GPS would not be charged when I use in my car. (the cigarrete lighter is in good condition). I tried to use another new cable...
The cigarette lighter adapter has a fuse in it, Carefully unscrew the Silver tip of plug, Carefully its spring loaded... and check the fuse..
Did you buy your unit with a credit card? If so you could possibly get a receipt,
Did you Register your unit with Garmin? If so they would have some kind of record when you brought it.
Nov 03, 2010 | Garmin nuvi 1490T GPS Receiver
Blowing number 2 fuse in dash panel
fuse #2 E7 D8 goes only at cigarrete lighter and to data link connector, remove the socket at the rear of cigarrete lighter and install fuse, change the cigarrete lighter when it is shorted or there will be a small piece of metal left inside the whole,
Aug 05, 2010 | 2000 GMC Jimmy
What can i do to fix my cigerette lighter. i changed the fuses and it still doesn't work.
You can check if it's the lighter or the lighter terminal fairly easy, It's most likely you have a car cell charger or something similar that works by plugging it to the cigarrete lighter terminal, check if it works, if it does your lighter is bad, those are fairly cheap and you can buy one on a dealer store or a good auto parts store. Good luck
Mar 02, 2010 | 2002 Chevrolet Impala
Is the cigarette lighter also the plug for cell phone charger?
The cigarette lighter plug should also work for the phone charger as long as the phone charger uses the cigarette lighter style plug(long with two metal contacts on the sides and a button contact on the tip). Most standard car chargers will fit both cigarette and auxillary style plugs.
Dec 29, 2009 | 2004 Ford Focus
2003 BMW X5 4.4L, cigarret lighter does not work
have you checked the fuse for the cigarret lighter in the fuse box. You should be able to look in the car manuel to see which fuse is the cigarret lighter then pull it out with either needle nose pliers or a provided fuse puller and check to see if the little wire inside the fuse is broken. if it is then replace that fuse with one of the same amperage rating. If not and you really want to get into it buy or borrow a volt meter with a continuity tester (checks if wires have breaks and shorts in them) and test contiuity from one lead of the cigarret lighter to the other with something plugged in and on that you know works like a phone charger. Then test from the positive lead of the battery to the positive lead of the lighter and the negative lead of the lighter and something grounded like the car's frame or a body panel that is bare metal like the floor board make sure you scrape a little paint off to test this.
Aug 06, 2009 | Car Audio & Video
1996 Camry LE 4 cylinder, cigarete lighter
If the cigarrete lighter plug still has power then is more likely a defective lighter. I've just replaced the lighter on my Tercel so I would suggest to borrow one to try the plug before buying a new one.
Good Luck.
Jul 06, 2009 | Car Audio & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
