<!-- from fixya rte -->Sony receiver str-605 protector flashing - Audio Players & Recorders
    Top Expert:
  • Audio Player... Master
  • 75,462 Answers
Short circuited component/s at its audio output stage circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 09, 2014
SOURCE: STR DE435 PROTECTOR STR DE435
I have the same problemwith mine. the protector sign is on- I do not know why- and do not know what to do about it. Let meknow if you do or if you get assistance and I will do the same. My e-mail address is 1971CJS@Bellsouth.net
Posted on Feb 28, 2008
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
SOURCE: protector mode SONY STR D1011S am fm receiver
I've had this happen, it's when you have speaker wires crossed.....
Posted on Sep 22, 2008
smarthome2
  • 1114 Answers
SOURCE: flashing protector code 22
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
smarthome2
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
Posted on Jun 13, 2010
Sony receiver str-De605 protector flashing
try a reset on unit but unit may have a faulty pa stage
Nov 09, 2014 | Sony STR-DE605 Receiver
Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
Jun 18, 2009 | Sony STR-DE435 Receiver
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
Sony str-de935 protector flashing have to shake amp
Sounds like a bad solder connection. check around input jacks and tighten the screws that hold the circuit boards and the heat sink.
Jan 31, 2009 | Sony STR-DE935
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Dec 31, 2008 | Audio Players & Recorders
The protector light starts flashing every time I try to use my sony tuner.
My protector light flashes on and off, whats up with the reciever ?
Jun 22, 2008 | Sony STR-GX700ES
STR-DE915
if your preferring to protect light your either, pushing to much power, or a wire could be touching along the line. Check all your wiring even the ones behind the receiver that could be your problem
Mar 10, 2008 | Sony STR-DE915
Protector flashing sony da80es
could be fuse inside open it up cheak all cheall all conections start with just 1 unit in it
Feb 06, 2008 | Sony STR-DA80ES Receiver
 Grubhead
Grubhead
