Question about Singer 8763 Curvy Electronic Sewing Machine
I have the Singer Curvy 8763 and I can not fix the tension. I've tried messing with the top thread tension and the bobbin tension, but it never stays consistent with I sew. Any suggestions? I'm so fru
I have the Singer Curvy 8763 and I can not fix the tension. I've tried messing with the top thread tension and the bobbin tension, but it never stays consistent with I sew. Any suggestions? I'm so frustrated...
    Novelist:
  • 193 Answers
Try Singer tech support. Use their phone service.
1-800-4-SINGER (1-800-474-6437)
Monday through Friday, 8:00 a.m. to 4:00 p.m. C.T.
Posted on Nov 13, 2014
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
Zenqi
  • 208 Answers
SOURCE: Singer 3820 Bobbin Issues? I can't sew!
Unthread the machine completely, remove the bobbin.
Make sure that the bobbin case is securely in its place.
Turn the handwheel and ensure that the bobbin case is not jamming.
Turn the handwheel until the take-up lever is in the highest position.
Raise the presser foot and rethread the machine.
Chaeck the upper tension setting and set it around 5.
ALways make sure that you start sewing, stop sewing and thread the machine with the TAKE-UP LEVER IN THE HIGHEST POSITION.
Posted on Jul 11, 2009
  • 255 Answers
SOURCE: Singer 4623 bobbin thread won't catch
Hi! Did you by chance, change your needle? If so, make sure you have the flat side of the needle shaft facing the correct direction. If the needle isn't in all the way or the flat side of the shaft facing the right way, the bobbin thread won't pick up.
Let me know if this helps, ok?
Happy Sewing!
Posted on Feb 10, 2010
  • 1116 Answers
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Posted on Mar 13, 2010
Bottom thread seems too tight!!! Help!!!
If the bottom thread is tight there should also be loops on top and this means that the upper tension is too tight.
Get out your manual (http://www.singerco.com/uploads/download/1198_8763-efs.pdf) and turn to page 24. Under "ADJUSTING TOP THREAD TENSION" it tells you that if you're having thread tension issues, change the tension control dial on the top of your machine from auto. It also shows you a diagram with your problem illustrated on the right side of the page. The bobbin tension is set at the factory, so all tension problems can be solved with top tension adjustment. Set it manually and if it loops on top, loosen the tension a little. Test again. Repeat until loops are gone.
Using different colours on top and bobbin and a contrasting fabric (e.g. black top, white bottom, light blue fabric) means you can easily see what's happening. A perfect stitch is when you see exactly the same stitch pattern on both sides of the fabric. On top, the bobbin thread colour appears between stitches as a tiny dot and on the bottom, you see the top thread dot between stitches.
If it's impossible to get the tension right, take it to a technician, because it's a sign that the hook timing needs attention.
Apr 21, 2015 | Singer 8763 Curvy
The top cotton keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 19, 2014 | Singer 8763 Curvy
Top thread will not catch bobbin thread
needle problem, thread or tension problem or, timing issue
Aug 05, 2014 | Singer 8763 Curvy
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
Whta is the answer to the curvy's thread/bobbin problems. super infuriating
If by "bobbin thread is usually too loose." you mean that you are seeing loopy stuff on top of your seam... then first you need to make sure your bobbin is un-spooling in the correct direction.
Also make sure that the tension spring on your bobbin case is not missing it's screw. Don't mess with the tension there yet... loosen your top tension first... sew on scrap fabric of the same type as your project. Loosen the top tension until you stop seeing loops on top of your seam. If you have loosened it enough to see loops on the bottom... tighten it a bit.
If all else fails make sure you re-thread the top thread with the pressure foot up position so you make sure you are getting the top thread in the tension discs and try test sewing again.
Jul 26, 2012 | Singer Curvy 8770 Electronic Sewing...
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
I have Singer Curvy 8763. It seems that the foot control stopped to work. The machine does not sew, its impossible to wind the bobbin. It is possible however to sew backwards with the help of reverse...
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Nov 04, 2010 | Singer 8763 Curvy
Singer 8763 Curvy Electronic Sewing Machine Logo
98 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
