Question about Home
Whats the difference in the ED17 & BD17 HPS light bulb
Cant seem to get the lights working with 115 volts at the bulb base receptacle...is there a starter or ballast issue with this fixture
  • 3,506 Answers
Not likely but what is the name/description of the system?? It is possible that the one is 115 volts and the other is 220 volts. Look to see if there is any indication anywhere. Look the system up on google search
Posted on Nov 09, 2014
HPS bulbs and fixtures are normally designed to use bulbs specific to that fixture. Many times one type of bulb will work while a similar looking one will not. Make sure you use only the type specified on the fixture and you avoid the problem.
2 Suggested Answers
  • 5089 Answers
SOURCE: i need a 12 amp 125 volt ceramic fuse cant find one what replaces it
WW grainger carries ceramic fuses, including 12 amp:
Copy following links:
http://www.grainger.com/Grainger/COOPER-BUSSMANN-Fuse-1BX44
You can also wire a fuseholder in-line:
http://www.grainger.com/Grainger/COOPER-BUSSMANN-Fuse-Holder-1CV90?cm_sp=IO-_-IDP-_-RR_VTV70300505&cm_vc=IDPRRZ1
Posted on Jun 27, 2012
I have a building full of 427G lights with 12-15 that won't work, but appear to have good bulbs. What is the issue?
Florecent or the yellow HPS bulbs? If HPS you have a bad bulb, or bad ballast. May be similar issues if florecent.
Mar 05, 2015 | Lithonia Lighting Home
My slide projector light won't come on. Every thing else works
Check the base where the bulb connects, pins get bent and don't connect to bulb at times
Nov 18, 2014 | Kodak CAROUSEL 650H ELH Light Bulb Lamp...
If there is 115 volts at the bulb receptacle should the bulb light up
the outside of the receptacle has to have continuity to ground to complete the circuit.
Nov 08, 2014 | Cars & Trucks
I have 115 v at the bulb receptacle but the bulb doesn't light up...whats the problem its a rab ff150 hps fixture
Does the bulb work in a different fixture? Sometimes the base of the bulb does not make contact with the terminal inside the fixture. unplug the fixture and then see if you can bend the center "not" connector up a little.
Nov 08, 2014 | Rab Lighting RAB FF150 - 150 Watt - High...
No light in door dispenser
The light bulb is located in the top panel just above the dispenser and to the front. Be sure to check the manual for bulb voltage, most of these used a 12 volt bulb and NOT a 115 volt. It looks like an old style small base Christmas tree bulb.
Mar 21, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My ballast making a humming noise but will not light up my 600w hps bulb?? small bit of purple light in the bulb when turned on but not lighting up?? tried a 400w bulb in hood with the 6oow ballast and...
NANOLUX BALLAST 400W-1000W
NANOLUX HPS and MH electronic ballasts can be light up
E-MAIL :cly@sznumber.com
Skype:sznumberballast
May 18, 2013 | Sunlight Supply 400 Watt Hps Sunsystem I...
Just bought 4 new 1000W Super high output HPS bulbs. Only one of them is really bright. The others are about 80% by eye. The brightest one is nearest to the transformer stack but the others don't...
A ballast for a 1000 240 volt fixture will lose a small amount of output over time , but should nt be too noticeable . I suggest you take one of the dimmer bulbs and install it into the fixture that has the brightest bulb in it now . If the new bulb is now the brightest of all , then you know your other ballasts have lost some intensity . I have also seen on some bulbs depending on the gas inside the glass( ex. HPS or Metal Halide) which gives off the different color , will take a while on initial start up , to burn at full intensity . It is also possible that you were given used bulbs which would explain the 20 percent loss in intensity . Good luck
May 30, 2011 | Sunmaster 1000w Hps Grow Light Bulb 1000...
Tag lights wont work on 2001 jimmy. I replaced the bulbs and they still wont work
remove the bulbs & check for 12 volt current with the light switch on using a multi meter or test light.(ground it to a clean spot on frame of the car) If there is dirt present in the receptacle sometimes it will not get a good ground. If you have 12 volts in the receptacle check the ground for continuity.
Sep 10, 2009 | 2001 GMC Jimmy
CAN YOU TELL ME ALL THE COMPOMNENTS ON A COOPER 200W HPS 120V. LAMP COBRA HEAD STREET LIGHT. I JUST PERCHASED THIS LIGHT AND I'M HAVING PROPLEMS GETTING IT TO WORK
200 watt  High Preasure Sodium 120 volt Attach the 120 volts to the lamp and turn it on,or cover the light sensor if it is an automatic on light.  Their is really not much to them. A ballast (transformer) and photo electric eye to turn them  off and on and the bulb. If covering the sensor doesn't make it operate then it is  most likly a bad bulb.  When starting these HPS light,thetyy take approximately five minutes to come to full brightness.    Hope this helps.
Dec 21, 2008 | Computers & Internet
Home Logo
331 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
