Question about Audio & Video Receivers
Audio sync with tv video
Surround sound output from TV thro Sony HWS-BTA2W Bluetooth transmitter to Sony CMTDH5BT gives a time lapse and out of sync audio with the video. Any solution.
  • 3 Answers
SOURCE: Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Posted on Jan 27, 2008
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: connecting blu ray to surround sound receiver to tv
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
Posted on Jan 08, 2009
  • 37 Answers
SOURCE: Failure to sync
1. Check that the headphones are transmitting, normally theres a coil inside the headset that picks it up, depending on the system if I was transmitting 3V in I get out about 1V across the coil after that it then thows it to serveral transistors for amplification then to the speakers.
Posted on Aug 04, 2009
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
  • 58 Answers
SOURCE: I have a Sony Bluetooth transmitter/receiver -
Have you tried going into control panel, sounds, and setting the USB speakers as your default audio device?
Posted on Nov 21, 2009
0 characters
1 Points
Have no sound on my surround sound sony
Could be a number of things try each and test!
  1. Make sure the MUTE function has not been activated.
  2. Try turning up the volume level.
  3. Check that there are no headphones connected.
  4. Try setting the Audio/Video (A/V) receiver to a different Surround Sound mode. IMPORTANT: Verify that the source you are playing is encoded with Surround Sound audio. If not, the audio will be very difficult to hear using a Surround Sound setting. Set Surround Sound to OFF when playing a source that is not encoded with a Surround Sound signal.
  5. Check each speaker to make sure they are properly connected to the A/V receiver.
  6. Perform a Test Tone function to verify if the speakers are working correctly.
  7. Verify all external audio sources are securely connected to the appropriate inputs on the A/V receiver. NOTE: If the audio is being sent from a television to the A/V receiver, then it may be necessary to disable the internal speakers of the TV or set the audio output of the TV to FIXED or VARIABLE. If the audio output of the TV is set to VARIABLE, then you will need to increase the volume level of the TV.
  8. Make sure the correct audio input is selected on the A/V receiver.
  9. Confirm what type of HDMI devices are connected to the A/V receiver and then check the following:
    1. Test each one of the HDMI inputs on the A/V receiver to confirm that all of the inputs for the A/V receiver are working.
    2. Try a couple of different HDMI cables to verify there is not a bad set of cables.
    3. Unplug the video source from the A/V receiver and connect the source directly to the television. If there is still a problem with the audio, continue to the next step. If connecting the source to the TV corrects the sound issue, service will be needed on the A/V receiver.
  10. Verify the DEMO (demonstration) mode is not active.
  11. Change the ATT (attenuate) setting. NOTE: The procedure to change the ATT feature varies by model.
  12. Reset the A/V receiver back to factory specifications.
Dec 21, 2014 | Sony Audio & Video Receivers
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Having trouble syncing audio with my new led tv. I run audio thru a sony receiver model str-dg520. Where do I find the settings to make it sync?
Normally you would to the TV settings under audio you would have to disable the tv audio and point it to your receiver I assume you have a surround sound. Make sure you are also using the right audio cable RCA or digital optic cable
Oct 24, 2013 | Yamaha Rx-v465/rxv465 Home Theater...
Hdmi to component connection for surround sound
Does you tv have an optical audio output? That would be the easiest way.
Jan 07, 2013 | Marantz Sr8200 Thx Ex Surround Dolby...
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio & Video Receivers
How do i play my ipod through my pioneer VSX-108 receiver
I am using a sony bluetooth transciever md# HWS-BTA2W with a Y adapter into the Receiver CD audio in. Works great and I am able to roam about the house with my ipod playing audio through the VSX-108
Dec 22, 2010 | Pioneer VSX-108
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Apr 30, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Very low sound on TV and DVD no tuner
audio out from your tv to your reciever gives low output? how do you have everything hooked up i have vcr to tv dvd to vcr audio to my reciever and vcr tv thru piggy back plugs therefore i can only have tv audio or reciever or both
Dec 03, 2008 | Denon AVR-2800 Receiver
Audio & Video Receivers Logo
212 people viewed this question
Top Audio & Video Receivers Experts
Are you an Audio and Video Receiver Expert? Answer questions, earn points and help others
