Question about Dishwashers
Why does my kitchen aid model # KUDKO1ILBS6 start all by its self. I can't stop it and the control panel blinks and I have no control over it. I have to unplug it to stop it. Then it gets to the rinse
Starts all by itself and no way to stop it. Unplug and starts all over again then it won't drain.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Sounds like it might need a service as it sounds like there are some major issues. Contact your local shop that can help you.
Posted on Nov 09, 2014
  • 44 Answers
SOURCE: my dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Posted on Sep 14, 2007
  • 1314 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
SOURCE: Kenmore Dishwasher does not wash
my problem is the motor hummms for a minute or so and turns off. Could this be the capacitor? how do you test a capacitor?
herb
Posted on Jul 14, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
vector006
SOURCE: Cycle starts then stops and Intake/Drain light comes on
Hey All.
I had the same problem with my Miele g843, and i finally got to the root problem.
My machine would drain ok, and fill ok, but when it tried to start a cycle, it would do nothing. I could hear a relay occassionally clicking until it finally gave up and signalled the blinking red light of death.
I first checked the inlet filter, drain pump and drain pipe but I discovered no obstructions. So I started taking the dishwasher apart, and discovered that the main pump was seized! This may not be the source of YOUR problem, since it could be many things, but this worked for me. Here are the instructions to remove the pump and get it moving again:
Pull out the dishwasher and disconnect the power, water and drain lines.
Empty all water from the unit (disconnect drain line and let the water drain into a low profile container) you may have to elevate the unit and tilt it rearwards to get the remaining water out.
Remove the side panels of the machine.
Lay the unit on its side elevated about 2-4 inches above the ground (be careful you don't put direct pressure on any of the internal components when you support it)
Remove the 4 screws that hold the base panel to the frame of the machine.
You can now see the motor.
Disconnect the electrical connections to the motor and the pressure sensor.
Disengage the clamps that hold the rubber hoses to the motor and slide the hoses off the motor.
Unscrew the single bolt that holds the motor inplace on the back panel of the machine. Pry the rear panel out slightly to release the dowel pins and gently pull the motor towards you (pivoting on the inlet grommet). Once you have the motor out, you can try to manually turn it by rotating the impeller. If it is stiff, you could have the same problem mine had. Using silicon spray with a nozzle extension, spray the seal between the impeller housing and the motor and continue to spin the motor manually until it becomes free spinning. If this doesnt work for you, you may need a new motor ( i never priced one out but it cant be cheap ).
If you get stuck somewhere email me and i can send you pictures: vector006 at hotmail dot com
Cheers!
Posted on Mar 01, 2009
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
I was running the self-cleaning and it stopped working. the door will not open, and the control panel is all black. I've been told this is a very common problem with this model and it's either the...
Hello, Thank You for using FixYa. I will be helping you today.Yes it is common it is part number 8300802 It is located on the back just remove the back panel and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | KitchenAid KGRA806P Gas Kitchen Range
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
It is obvious that there is a major design problem with this model in that numerous enquiries under Kitchen Aid's "popular solutions" deal with a multitude of self-cleaning issues. We have had to...
NEVER use the self cleaning mode.
Jan 25, 2011 | KitchenAid KESA907PSS Electric Kitchen...
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
Control panel cover falling apart
i looke dup your model and you seem to have the hidden control panel model. the manufacture is funny htat way they will only cover part if you have installedby auth servicer, i looked up the part for you part number 8531269 retails for about $70. its the enitre console assy including overlay. so although they cover it youd be better off buying it direct and installing your self for sure. simple enough repair, the screws (torx15) from the inner door panel come off and release the panel, everthing on the inside simply unsnaps and gets transferred to the new part. just remember to disconnect power first all live wires!
Nov 06, 2008 | Dishwashers
Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Feb 01, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
