Sony MHC rv6000 freezing after 1 munits
When I turn it on, the demo runs perfectly. after 1 munit, its internal relay clicking sound appears few times and it goes freezing slowly. first display appears " Surround off" " Surround on" few times. and then it hangs up. power button not works, display off, but system and fan still on. i disconnected all DVD/CD connectors but no success, I only want to listen FM but facing the problem Please guide me what to do ?
SOURCE: Sony MHC-GX9900 Shelf System
i have the same problem with the blinking light this problem is due alot to over heating be careful your fan is not burned up or is not being blocked it is a protect mode activation to prevent overheating
Posted on Aug 25, 2008
smarthome2
  • 1114 Answers
SOURCE: dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Posted on Jun 02, 2009
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
SOURCE: The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Posted on Oct 05, 2009
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID uttamkholiya@yahoo.com
any sony music system problem
Posted on Nov 07, 2009
Coleman central ac is not shutting down. Thermostat clicks off but compressor and fan keep running and cooling
This is either a stuck relay or contactor or the Tstat is bad.. Try shuting down the power to the unit and wait for about 3 munites and trun it back on .. if that does not clear it up My money is on a stuck contactor
Jul 15, 2011 | Heating & Cooling
AN ISUZU RODEO 95 4WHEEL. the A/T OIL TEMP red light flashed in the morning on my wayto work and on my way back it stopped moving like it was in neutral. i came down from the vehicle and found out that hot...
id not drive any car with trans leaks.
is buying a new box for $3000 , good idea on old 95 car?
really that be end of life for that car, with a bill like that,
more than car is worth , running or not.
nice tortture(sic) test,
learn to respect expensive complex transmissions.
and win.
IMO
who, get it fixed and stop driving it, you are only making it worse.
and more expensive.
Mar 09, 2017 | Isuzu Rodeo Cars & Trucks
Not really a problem, Ijust want to know how long a normal cycle should last.
wash cycle is between 10-14 munites. rinse cycle is about 10 munites. pluse time to fill and discharge water from the tub. total time should be about 40-45 munites
Apr 22, 2009 | LG LDF6920 24 in. Built-in Dishwasher
Papa jim-akai PDP4225 42 in plasma slow on worm up
You can hope for a loose solder connection. Even this hopeful solution requires a long time of holding a solder iron.
Nov 13, 2008 | Akai PDP4225M 42 in. Plasma Television
Put new ignition in 2003 sunfire. engine wont stay running and theft lock symbol on in dash
HI.
Follow this step to keep running your sunfire.
1 - Be sure the battery is full charged.
2 - Is better if you put a battery charged
3 - Turn the key to run position and tray to start the car and leave with the key in run position,
With a watch let pass 10 minutes no less. you gonna see the security light flashing and stop flashing after 10 munites.
4 - After 10 munites turn the key to off position during 30 seconds, with watch on your hand, OK.
6-- After the 30 seconds try to star the car
I hope this solve your problem.
Please letme know.
Thank you for use fixya.
Jul 11, 2008 | 2003 Pontiac Sunfire
TOSHIBA A125 LAPTOP POWER STUCK UP
hi venji,
you question was still not clear. If I'm not wrong you mean to say after 20 mins your computer screen when black and you could not see anything, right ???
did you try to touch the power buttton to turn it on again maybe its in sleep mode.
Or you mean after 20 min..laptop still work but you hardly can see due to no light (back light )??
so I'm not really sure ..please give us more detail.
takecare.
May 29, 2008 | Computers & Internet
Picture freezes
What horror, it must be an RCA, no no a LG, no no maybe a cheap Walmart brand inported from China, ya that got to it,
Not enough info, can't answer.
What About bob
Mar 01, 2008 | Televison & Video
Pitcure no sound
Try unplugging the set for a munite and check the internal/external switch on the back if this model has one. If sound is not restored you have audio circuit problems
Oct 14, 2007 | RCA P60921 60" Rear Projection Television
Jul 04, 2007 | Sony MHC-GX9900 Shelf System
 Grubhead
Grubhead
