Question about Singer Sewing Machines
I have a Singer 5050 I can't set the pattern#, when I set it, goes back to where it was set.
    New Friend:
  • 3 Answers
I guess you already figured it out, but there usally ia
Posted on Nov 09, 2014
3 Suggested Answers
  • 2386 Answers
SOURCE: singer 5050
Does your sewing machine create unwanted loops or does the thread snap on the top of your machine? Does it seem like your machine does not want to work with you? Your problems could be related to tension. First off, I recommend putting a white thread in the bobbin and a black thread through the needle. This will be imperative as you will need this to learn which thread is your main problem.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis. If you see loops of black, your needle tension is too loose or your bobbin is too tight. First try tightening the main dial on your machine to a higher number. If that does not work, try using a small screwdriver to turn the screw underneath the bobbin-case in the front of your machine clockwise. Please remember that even a little turn can mean everything in your work. I recommend only turning it 1/4th of a turn each time you test it. Now if the loops were white, it means your bobbin tension is too loose. Do the same as above, tightening the screw clockwise with a screwdriver. If it seems too tight, please do loosen it and try to find a happy medium between your needle thread and your bobbin thread. If the thread snaps, your tension is too tight. Do the reverse of the above. Either lower the number on your needle if the thread is snapping or turn the screw on the bobbin-case counter-clockwise. Again, each little bit of the turning counts, so only turn it about 1/4th the way. It is always good to be extra careful. Keep working with both until you get a nice even stitch. An even stitch means the black should be on the top of your fabric and white should be on the bottom. It is perfectly okay if you see a little speck of one on the other side. If all fails, try putting two drops of sewing machine oil in your machine and let it run through for about five minutes. The mechanisms might be a little overworked and are having a problem with your machine. It is good if you keep a lot of fabric scraps available in case you over oiled. You do not want to be working on a difficult project for your sewing machine only to spit some oil on it. Keep sewing on the fabric scraps until there is absolutely no residue from the oil. Putting any more that 2 drops as stated earlier might cause more problems than you expect. Always use the oil sparingly. If none of the above solutions have worked and you feel frustrated by your machine, a local Sewing Repair Shop visit should only run you about $40 and is highly recommended for your machine. A professional can tell you if what’s wrong with your machine is fixable at-home or not. A full repair for older machines before working with them is highly encouraged.
Posted on Sep 15, 2009
  • 139 Answers
SOURCE: threading a singer 5050?
http://www.singerco.com/resources/threading.html
This is an awesome site!
Posted on Apr 05, 2010
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
I need to get a instruction manual for singer sewing machine 5050C. Serial NBR. C01402098
Singer manuals are available from their website.
Browse to http://www.singerco.com/accessories/instruction-manuals
and in the search field type in your model number, in this case, 5050, then click "search".
Most manuals are free to download as pdfs.
Aug 01, 2011 | Singer 5050 Mechanical Sewing Machine
Need Singer 5050 manual - is there a free downloadable version?
Yes, go to www.singerco.com and under customer support you will see instruction manuals, then enter 5050 and you will have your free download of your manual to save to your computer.
Jan 29, 2011 | Singer 5050 Mechanical Sewing Machine
I bought a 5050 model on ebay and the handwheel is
Unless you want to deal with the little screws to take it apart, you may take it to an authorized singer service dealer. Look in your local yellow pages under sewing machines.
Apr 08, 2010 | Singer 5050 Mechanical Sewing Machine
I have a singer 5040c and it won't do a zigzag stitch - it just goes in a straight line.
My wife just had this a similar problem with her Singer Omega 36 where she could sew straight and select patterns but could not zig zag. If you open the top of the machine you can see where a little lever connects to the white plastic pattern module that gets inserted in the top. The reason for the problem was that the lever was not touching the bottom of the module properly. The notches on the module cause the needle to move from side to side creating a zig zag. The module needs to be inserted correctly, by this I mean fully and the correct way around or it does not reach the lever when it is in the A position. At first inspection it looks the module could be inserted any way around but there is a thin and a fat clip. You need to try both ways to see which on sits lower in the machine. You may now need to adjust the tension on the machine as the lever will nowe move differently inside the machine. This fixed my wifes problem.
Mar 23, 2010 | Singer 5050 Mechanical Sewing Machine
Thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Mar 12, 2010 | Singer 5050 Mechanical Sewing Machine
Singer 5050 won't zigzag stitch
I have this same issue with that same machine. Did you ever figure out what was wrong with it??
May 08, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
