Is it possible to unlock front loader washing machine without ending the wash cycle
    New Friend:
  • 25 Answers
Yes you would have find the manual door release and pull it
Posted on Nov 26, 2014
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
Karthik316
  • 187 Answers
SOURCE: Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Posted on Jul 06, 2009
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
How do I remove the locking function on my washer when already begun cycle so I can add an extra item I forgot put in without having start again. Is it possible?
On later model front loaders they have a Stop & Add button so when engaged you can add more to the wash load. Unfortunately earlier washers don't have it so once the cycle starts that's basically it. That's the reason some people prefer top end loaders as it not a issue
May 28, 2016 | Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
My washing machine is not draining and finishing the cycle
There should be a trap to catch small items that might slip past the seals of the drum. find it and clean it out. That might correct the problem.
However, you might be using too much or the wrong kind of laundry detergent. Front loaders can't use regular top loader detergent. Too much suds can cause the machine to stop. that may be why you find suds in the drum when you think the washing should be done.
Some units have lights that change as the washing process changes what it is doing. If it's working properly, the light indicating the door is unlocked will be lit at the end of the washing cycle. If the machine stops short of that, something is definitely wrong with the machine and requires a thorough inspection by a professional.
Jim Hart
Jun 20, 2010 | Asko W6021 Front Load Washer
How do I unlock my whirlpool front loader
Press and hold "End of cycle" button for 3 seconds to unlock control.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water in washing machine
Front loader or Top Loader? If front loader you probably put to much in and at spin cycle the tub hit the hose to the pump and possibly got knocked off?
Oct 16, 2009 | Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Control locked light is on, machine is currently inoperable.
Push and hold the end of cycle button for 3 sec to lock or unlock control panel. here is the manual if you need.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606218.pdf
Good luck and please rate FixYa!
Apr 13, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
